Topic: Wind Bag vs Air Bag  (Read 6266 times)
Offline Bugthug
Wind Bag vs Air Bag
« on: February 17, 2010, 03:52:07 PM »
The air bag light came on this morning on our '05 Beetle. Anyone know what it means and is it okay to drive? Thanks for any help.
Wind Bag vs Air Bag
« Reply #1 on: February 17, 2010, 08:16:40 PM »
It is ok to drive,  the air bag system has sensed a problem with a compnent,  is it under warrenty?,  the air bag system may still deploy airbags and safty features in an accident,  my guess would be the pods system for the passenger seat, is it a convertable? excuss spelling
Offline swagginjello
  • cleveland, tn
    • facebook...
Wind Bag vs Air Bag
« Reply #2 on: February 17, 2010, 08:21:29 PM »
mines been on for about a year due to a short in the driver side seat belt recepticals.  :?
Wind Bag vs Air Bag
« Reply #3 on: February 17, 2010, 08:26:28 PM »
the seat belt latch is a pretty easy fix,  pull the seat and change out the latch,  they are pretty pricey, what color is yours i think i have on in the tool box
  • cleveland, tn
    • facebook...
Wind Bag vs Air Bag
« Reply #4 on: February 17, 2010, 08:32:02 PM »
mines grey, seems like it was almost 300, but that might have been instaled when i checked on it last. i've been told i might be able to clean it with some contact cleaner, but havnt been to worried about it, but id be nice not to see that light everyday!
Wind Bag vs Air Bag
« Reply #5 on: February 17, 2010, 08:37:54 PM »
i think the one i have is tan and i will check which side, you always change
Wind Bag vs Air Bag
« Reply #6 on: February 17, 2010, 10:02:45 PM »
Quote from: "swagginjello"
Contact cleaner prob. ain't gonna help.  Usually what happens is the harness breaks near the buckle assembly.  twist the buckle back and forth, look at the harness (taped up / running with the actual cable / bracket that the buckle is attatched to.)  Usually, you can see the actual wire broken.
  • cleveland, tn
    • facebook...
Wind Bag vs Air Bag
« Reply #7 on: February 17, 2010, 10:50:07 PM »
ill take a closer look at it, might just have to take the seat out to get a good look, its a bit tight in there.  a little solder  probly wouldnt help i guess... itll probly still throw of the resistance.  :?
Wind Bag vs Air Bag
« Reply #8 on: February 18, 2010, 06:14:30 AM »
Correct.  do not solder wires on a VW, they don't like it.  Airbag wires are especially sensitive.  The way i was talking about checking the buckle can be done without taking out the seat.  fold the buckle all the way left, all the way right and look where the wires go into the bottom of the buckle, if the wire is actually broken, you should be able to see it right there where it goes into the plastic body of the buckle.
When they break there, there is no good way to fix them.  Just to replace the buckle assembly.
Offline Bugthug
Wind Bag vs Air Bag
« Reply #9 on: February 18, 2010, 06:31:31 AM »
As always, thanks Travis, Rick and everybody. Hannah's driving this car to school now and things like this make a daddy nervous! You know.
Wind Bag vs Air Bag
« Reply #10 on: February 18, 2010, 09:55:27 AM »
swagginjello, if you want the buckle i do believe it is for the dr side it is tan you can have it for 30 bucks,  it is new
  • cleveland, tn
    • facebook...
Wind Bag vs Air Bag
« Reply #11 on: February 18, 2010, 08:23:44 PM »
sounds good to me.
