Topic: what happens when you run your watercooled 1.8 hot  (Read 2615 times)
« on: November 03, 2010, 08:42:46 PM »
pulled a head off a 2004 beetle the other day and got so hot it melted the aluminum and splattered it in the piston and cylinder
Re: what happens when you run your watercooled 1.8 hot
« Reply #1 on: November 03, 2010, 08:43:59 PM »
the second picture show where the valve seat and water jacket were exposed,  the first is what it should look like
« Reply #2 on: November 03, 2010, 08:56:50 PM »
I need to post a couple pics up....
I had a 2001 Audi A4 with a 1.8 Turbo a few days ago that popped a hose fitting, ran out of coolant, and dude kept on rolling.  it got so hot, it melted the plastic housings that bolt to the engine, and the round plastic water pump impeller was oval instead of round.  The timing belt was a frayed, sticky, molten mess, but never jumped time.  I replaced the melted parts, did the timing belt and all the trimmings, filled the coolant back up, and it cranked right up.... After a little low compression fast spinning noise.   ;)
DAY-YUM.
« Reply #3 on: November 04, 2010, 06:37:09 AM »
have seen the melted coolant flange,  i have also seen the valves loose there seal becuse of overheating
