Topic: two dash light questions..  (Read 2944 times)
Offline agrezy1
« on: May 12, 2012, 12:55:22 PM »
2 icons on instrument cluster.
1st is lower left corner pic of a bug with what appears to be a air flow arrow going out the back.
2nd upper left corner triangle with explamation point in the triangle with an circle arrow going around it
also what is the asc button on dash for near the hazzard button?
Offline agrezy1
Re: two dash light questions..
« Reply #1 on: May 12, 2012, 02:16:02 PM »
my bad button says asr on it
« Reply #2 on: May 12, 2012, 02:43:23 PM »
The asc button takes the traction control off,  the beetle with the wind should indicate the power spoiler,
« Reply #3 on: May 12, 2012, 02:44:42 PM »
Pictures would help greatly, but from your description, the picture of a bug sounds like your immobilizer indicator. It's supposed to be a key.
Triangle with an exclamation point and a circle going around is your traction control symbol. The ASC button is what disables/enables traction control.
All of this is explained in your manual by the way 8)
« Reply #4 on: May 12, 2012, 02:45:13 PM »
The triangle with the circle is the traction control light,  if there is a problem it can come on,  usually with the engine light or abs light or if you turn off the traction control
Offline agrezy1
« Reply #5 on: May 12, 2012, 09:40:55 PM »
if i had the manual i probally wouldnt be asking this but thanks for the helpful hint ;D
« Reply #6 on: May 14, 2012, 06:45:35 AM »
It's okay... years of experience at the dealer showed me that just because you have the manual doesn't mean you will actually open it up and try to figure it out....  :D :D :D
I was guilty on more than one occasion of leaving owner's manuals in the front passenger seat, open to the applicable page.   ;D
