Topic: Happy happy joy joy...well almost  (Read 2235 times)
Offline vdubluv
  • Keep on_keepin' it on
« on: February 05, 2013, 06:48:00 PM »
It seems I have a lot of wiring work to do in order to have working fog lights in my MkIV. I've done the easy parts. Got the GTI hd lmps. I've had the Euro switch. I will be getting a 53 relay.
The hard part is going to be adding the wiring from the relay and fuse to the hd lmps and to the switch. The led lights in the switch already, when pulled one notch out. I don't believe the original harness is loaded with a wire from the switch either. So, I am going to be doing a wire up from switch, to relay, to fuse, and to hd lmps. Lots of work.
Anyone want to help? Hee hee =•)>
Has anyone done this?
mek
Offline vdubluv
Re: Happy happy joy joy...well almost
« Reply #1 on: February 06, 2013, 11:14:23 AM »
To those unaware or interested, there is a wiring kit with relay and in line fuse for OEM fogs, if you really don't have to have a factory wiring job. ECS has one and of course an aftermarket version for the bmpr grilles. Hail to the yeayah.
mek
