Topic: Can't find one...  (Read 4603 times)
Offline casper
Can't find one...
« on: June 15, 2013, 03:50:09 PM »
We need to replace this on Casper, who is a 1991 Cabriolet.  Can anyone give us any ideas?  Hugh called Village; no luck there.
And what is it actually called?  Thanks!
Re: Can't find one...
« Reply #1 on: June 15, 2013, 04:26:36 PM »
If you can't get a new one, and can't find a used one locally, I'd try eBay or Pull-A-Part.
I'm not sure what years would interchange, but there are two Cabriolets at Pull-A-Part East Atlanta that were put on the yard earlier this week.  It's a long drive not knowing if they are manual or automatic, and if they are automatic, is the part still there . . . and if it's still there, is it any better than the one you already have.  I'd go for it . . . but then, I've used needing a connector for the radio wiring harness for my S-10 as an excuse to go play in the junk yard.   ;D
« Reply #2 on: June 22, 2013, 03:18:08 PM »
It's called "trim for shift mechanism" in the parts system.
155-863-215 or 533-863-215 both part numbers use color code 01C.
The cover strip/slider is 321-863-277-A.  Also 01C color code.
Pull the cover off and look to see if the part number starts with 155 or 533.
Offline casper
« Reply #3 on: June 26, 2013, 07:29:35 PM »
Thank you so much!  That really helps.
Pull a part is a good idea too if we can't find it online...
