Topic: cabrio fans wont stop until the battery runs down  (Read 2831 times)
« on: August 14, 2010, 08:39:19 PM »
have a 99 cabrio that the fans stay on after the switch is turned off.  I tried unplugging the sensor on the radiator and the fans keep going.  If i unplug the fan module with the 8 pin connector they stop running.  i checked the wiring diagram and am not sure what would keep the fans running.  while the car is cold and running the fans do not stay on,  they do come on when the ac is turned on.
Offline DieselDoc
  • Chickamauga, GA
    • S&P Automotive
Re: cabrio fans wont stop until the battery runs down
« Reply #1 on: August 15, 2010, 12:10:23 PM »
sounds like the module itself has gone bad, that J103, I have a spare or two you are welcome to try,
The sensor in the radiator is working if it is coming on, it sounds like the relay is sticking or something, the temp sensor will tell it to shut down but if the relay is not disconnecting its not the sensors fault.
sal
« Reply #2 on: August 15, 2010, 04:44:40 PM »
if the module is bad i would think that it would still run after i unplugged the 8 pin connector,  when i unplug it the relay clicks and the fans go off with the 4 pin connector still plugged in.
« Reply #3 on: August 16, 2010, 10:47:55 AM »
the part number on the module is 357 919 506a
  • Trapped in a salad.
  • Aircooled Necromancer
« Reply #4 on: August 16, 2010, 12:59:24 PM »
I'd try the relay then. If it doesn't work, just take it back.
« Reply #5 on: August 16, 2010, 01:15:01 PM »
the relay is part of the module and most places will take returns on electrical stuff
« Reply #6 on: August 16, 2010, 02:32:05 PM »
Get one of the ones Sal offered and try it then.
