Tech. Center
Water-Cooled VW Tech
ABS light stays on 95 Cabrio
Topic: ABS light stays on 95 Cabrio (Read 3685 times)
green1
Always on the road.....
December 07, 2010, 10:32:33 AM »
The ABS light came on yesterday and stayed on. We are total noobs, and don't even know what this light is for.
Any help?
1995 Cabrio GL
2000 New Beetle
certdubtech
In the Garage...
Re: ABS light stays on 95 Cabrio
December 07, 2010, 11:24:36 AM »
Could be several things causing the ABS light to come on. I have a factory scan tool that can read the codes for it if you wanna swing by sometime, i can do a quick check just to see what the fault is causing it.
green1
December 07, 2010, 12:41:14 PM »
That would be awesome! Home or the shop?
1995 Cabrio GL
2000 New Beetle
certdubtech
In the Garage...
December 07, 2010, 12:44:35 PM »
I keep the scan tool here, at work.... come on by some time. It may take some time to figure out a problem, but the codes are quick to retrieve, i can do that while you wait.... kinda like window regulator "fixes"....
green1
December 07, 2010, 12:47:14 PM »
Will do. Be prepared anyway, I was hoping to talk to you about a winter project or two.... Bwahahaha
1995 Cabrio GL
2000 New Beetle
green1
December 07, 2010, 01:05:52 PM »
Are you still there till 5:30 or so? I drove another car today, so I'm going to run home and try to make it unless you leave earlier.
1995 Cabrio GL
2000 New Beetle
certdubtech
In the Garage...
December 07, 2010, 01:20:47 PM »
I am usually here till 5:15 or 5:30 at the latest, Won't be working this Thursday.
green1
Reply #7 on:
December 07, 2010, 01:23:51 PM »
OK. I'll come tomorrow. Thanks!
1995 Cabrio GL
2000 New Beetle
certdubtech
In the Garage...
Reply #8 on:
December 07, 2010, 01:25:30 PM »
Sounds good.
certdubtech
In the Garage...
Reply #9 on:
December 08, 2010, 09:15:56 AM »
A little heads up, Shannon.... i have to leave right at close/5 o'clock today. Won't be here thursday. If you want to try and swing by earlier, feel free.
green1
Reply #10 on:
December 08, 2010, 09:18:04 AM »
Thanks Rick. I hope to be there close to 4:15 if that's good for you.
1995 Cabrio GL
2000 New Beetle
certdubtech
In the Garage...
Reply #11 on:
December 08, 2010, 09:21:22 AM »
That should be just fine.
Tech. Center
