Topic: 2012 Passat 2.5  (Read 3881 times)
2012 Passat 2.5
« on: November 19, 2012, 06:02:50 PM »
So I am a Teachers Assistant in an engineering course at UTC and for a senior project, one group is setting up a dyno with a Passat engine that VW donated. They are having trouble understanding the fuel system, most specifically, the fuel return line and where exactly it comes off the engine.
Does anyone know how to describe this to me so I could pass it along? Perhaps Travis could snap a picture tomorrow?
Re: 2012 Passat 2.5
« Reply #1 on: November 19, 2012, 06:30:15 PM »
I believe the fuel return is built in to the fuel filter or fuel pump,  in the old ones It was def the fuel filter
Re: 2012 Passat 2.5
« Reply #2 on: November 19, 2012, 06:30:33 PM »
It has a built in pressure refukator
Re: 2012 Passat 2.5
« Reply #3 on: November 19, 2012, 08:58:06 PM »
Refukator? Is that German for something? :D
Re: 2012 Passat 2.5
« Reply #4 on: November 19, 2012, 09:16:33 PM »
Guess I didn't pay attention to my auto correct,  the would be regulator
Re: 2012 Passat 2.5
« Reply #5 on: November 20, 2012, 10:00:25 AM »
Ok, I haven't seen the engine test center and dyno yet, but I will pass that information along.
Thanks!
Re: 2012 Passat 2.5
« Reply #6 on: November 20, 2012, 10:11:14 AM »
Only fuel line in the engine compartment
Re: 2012 Passat 2.5
« Reply #7 on: November 20, 2012, 10:13:09 AM »
fuel filter set up,  blue is return and black is in and out on jetta 2.5
Re: 2012 Passat 2.5
« Reply #8 on: November 20, 2012, 10:49:35 AM »
awesome! I just forwarded the photos to the guy in charge of the fuel system. I knew you'd be able to help.
Re: 2012 Passat 2.5
« Reply #9 on: November 20, 2012, 10:59:19 AM »
No problem,  I imagine the passat is the same,  just have not seen one In the shop yet today
Re: 2012 Passat 2.5
« Reply #10 on: November 20, 2012, 11:34:57 AM »
Checked out a passat ,  did not see fuel filter next to tank,  suspect it is in the fuel pump
