Topic: 2011 Jetta wheels on a 2004 Passat?  (Read 4214 times)
« on: December 10, 2013, 04:22:48 PM »
Have a guy that has been asking to buy my BBS CH-028's (18's, A4 / A6 wheels) for the past 2 years...
Now that the tires are going, I am contemplating trading for a set of 17" alloys off his 2011 Jetta and some cash.
My question is to weather they will fit or not.
Sal? Dubtec? Travis? any one know?
Thanks.
Re: 2011 Jetta wheels on a 2004 Passat?
« Reply #1 on: December 10, 2013, 07:09:33 PM »
I don't think so but I'm not the expert,  I'll ask tomorrow
« Reply #2 on: December 11, 2013, 08:02:20 AM »
Thanks.
« Reply #3 on: December 11, 2013, 08:39:16 AM »
aren't they all 5x112? I guess the offset and/or width could create problems, but if they are both 5x112 the should bolt up
« Reply #4 on: December 11, 2013, 09:17:51 AM »
Ok yes they will
« Reply #5 on: December 11, 2013, 10:17:54 AM »
Offset should be between 35 and 45, I think...right?
« Reply #6 on: December 11, 2013, 10:24:12 AM »
Hummm that offset would work with the Ghia... hummmm.
Now If I just jack it up... masage the back fenders with a sawsall then I can have a Donk.
« Reply #7 on: December 11, 2013, 10:36:52 AM »
That would look like a triumph or a matchbox car,  the offset should be the same
« Reply #8 on: December 11, 2013, 11:32:35 AM »
They would bolt up to a later model bus...if you had one! I think you'd have to ream the lug bolt holes out to 14mm from 12mm but shouldn't be hard.
Get to trading!!!
« Reply #9 on: December 11, 2013, 04:14:35 PM »
I have ran that through the old brain...
I have a set of 245 40 ZR18's that would work as well for that application...
If I didn't have to ream them out I might try it...
