Poll
does anybody has a picture of the top view of the struts on a 93 golf
1 (20%)
2
4 (80%)
Total Members Voted: 5
Topic: 1993 golf  (Read 10914 times)
Re: 1993 golf
« Reply #15 on: August 29, 2012, 09:51:34 PM »
I too keep some Mahle filters on hand for all my cars.
Offline arty
Re: 1993 golf
« Reply #16 on: August 29, 2012, 10:32:36 PM »
ok i found the mann brand at advance. i isntalled the filter  now the beeping sound is off but the light will turn on at high rpms ?
Offline DieselDoc
  • Chickamauga, GA
    • S&P Automotive
Re: 1993 golf
« Reply #17 on: August 30, 2012, 07:06:02 AM »
And you changed the sensor? There are 2. The .25 bar (brown or blue usually) goes on the head. The 3.9 (white or black usually) goes on the filter stand. They are prone to going bad.
What weight oil are you using? Spec is 20w50 unless you live in Alaska or cold parts of Wisconsin.
Offline arty
Re: 1993 golf
« Reply #18 on: August 30, 2012, 10:18:15 AM »
20w50 really? i used 10w30, i only changed the sensor on the head, i will change the other one this afternoon, thanks.
Offline DieselDoc
  • Chickamauga, GA
    • S&P Automotive
Re: 1993 golf
« Reply #19 on: August 30, 2012, 10:48:01 AM »
The chart in the Bentley suggests 10w-40. However it's hard to find and as they increase in mileage the extra weight is not going to hurt IMO. It's not turbo charged so you are not pumping molasses into tiny needle bearings.
Change the one on the oil filter stand and I would say your issue will subside.
Offline arty
Re: 1993 golf
« Reply #20 on: August 30, 2012, 10:58:40 AM »
thank you all , for all the help.
Re: 1993 golf
« Reply #21 on: August 30, 2012, 11:05:14 AM »
Make SURE you put the right sensors in the right location!  I didn't realize there were two different pressure values until I put the same sensor in both locations.  I don't remember which one I used (seems like it was the 3.9 bar) . . . but I can tell you, It DID NOT work.   ;)
Re: 1993 golf
« Reply #22 on: August 30, 2012, 11:16:32 AM »
I vote we do #2.
Offline arty
Re: 1993 golf
« Reply #23 on: August 30, 2012, 11:52:21 AM »
I think i did the same Zen i installed the white sensor on the head  >:(   I need to read more before jumping into things   ::)
Offline arty
Re: 1993 golf
« Reply #24 on: August 30, 2012, 12:12:52 PM »
# 2 ?
Re: 1993 golf
« Reply #25 on: August 30, 2012, 12:49:37 PM »
Your poll man.
I am just saying that if we do #2, perhaps we can eliminate all the possibilities presented by the obviously inferior choice of #1.
But hey, like I said it is your poll.
If you wanted me to pick #1 then you shouldn't have given me a choice and just said point blank, "I am going to do #1, and I don't give a crud what you think...", but no you had to give me a choice, so I vote #2.
Apparently someone else agrees with me in that there are two #2 votes right now and that is trending at 100% of the popular vote.
 ;D
Offline arty
Re: 1993 golf
« Reply #26 on: August 30, 2012, 01:15:06 PM »
Oh i get it.  I'm new in this site and I'm learning on how to use it properly sorry for the error.
Re: 1993 golf
« Reply #27 on: August 30, 2012, 02:22:38 PM »
I'm just ribbing you, (normally David does this) but welcome to the greatest forum around.
Good luck with the Dub.
Let us know what fixes it.
Re: 1993 golf
« Reply #28 on: August 30, 2012, 03:15:06 PM »
 ::).    ;D
Re: 1993 golf
« Reply #29 on: August 30, 2012, 08:53:56 PM »
 ;D
So what your saying is that your number 2 on the poll has been seconded?
