Topic: 1989 Cabriolet Not Starting Problem?  (Read 13010 times)
Re: 1989 Cabriolet Not Starting Problem?
« Reply #30 on: March 08, 2011, 06:38:00 AM »
to drain it you could remove the back seat and access the fuel pump and siphon it out, cleaning it would most likley require removing it.
« Reply #31 on: March 08, 2011, 08:02:02 AM »
This might be a stupid question but is there a way of checking the air flow plate or cleaning the fuel distributor with something (i.e. fluid) without having to break it down first? Would it be a good idea to replace the braided fuel lines with new ones? Thanks again, guys.
If you are not VERY familiar with these systems, I would advise AGAINST disassembly of the fuel distributor... unless your intention is to disassemble it for the purposes of metal sorting before you throw it in to the recycling bins....  ;)
The other stuff is all peripheral... like you said, try the plate first, see what happens... you can take the injectors out (you need a special puller to do so), turn the key on, and lift up on the plate, see if they spray evenly... just disable the ignition first (funny story about a co-worker on that one)  key on, not cranking, just to clarify.   8)
And a big 10-4 on what Hal said... CIS cars hate bad gas.
Offline klp1569
  • hixson, tn
« Reply #32 on: March 12, 2011, 07:23:13 PM »
Haven't had a chance to check the plate this week. Hopefully will be able to get to it at the first of this week. If the plate is functioning, and the next step is the gas tank, does anyone recommend a place to take the car to have the tank cleaned, if that is possible? Thanks...
