Topic: 1989 Cabriolet Not Starting Problem?  (Read 13012 times)
Offline klp1569
  • hixson, tn
« on: February 27, 2011, 10:37:29 AM »
I have posted this original topic about a year ago thinking that I would be getting to the project but haven't til now. A quick recap of the original problem: I was trying to start the Cabriolet and while trying there was a loud pop and some smoke that came from the engine compartment. It looked like it was from the starter but couldn't be sure. After that, I would get nothing at all when turning the key except for the usual dash lights, radio, etc. I had read a post with a similar issue on a van and it ended up being the starter for them.
Yesterday, 2/26/2011, I put a new starter on from Autozone and nothing happened. Everything comes on just nothing from the starter/engine. Could other possibilities be the ignition coil, blown fuse/relay, bad wire, possibly siezed engine??? Any help and/or suggestions would be greatly appreciated. Before the pop the car was running. Thanks in advance.
Re: 1989 Cabriolet Not Starting Problem?
« Reply #1 on: February 27, 2011, 10:55:49 AM »
If the engine is siezed, the starter will still kick in, it just won't turn.  Do you hear anything from the starter when you turn the switch?
« Reply #2 on: February 27, 2011, 02:29:25 PM »
you need a test light and take the small wire off the starter and have some one else turn the key to the start position and see if the test light comes on, that will let you know if you are getting the signal from the ignition switch
Offline klp1569
  • hixson, tn
« Reply #3 on: February 28, 2011, 04:50:13 PM »
Thanks for the replies. I am not getting/hearing anything from the starter when I turn the key.
I will get a test light and try that. Am I correct in that the small wire is the one that attaches pushes on the terminal? I will admit that I don't know much about working on the electrical system.
Thanks.
« Reply #4 on: February 28, 2011, 08:15:03 PM »
yes the small wire pushes on,  you can use a jumper from the positive side of the battery and jump it to that terminal and the starter will activate and turn the engine over if it is working, this is for the more experinced and not the safest method, yopu dont want to have the car in drive or your wrench on the crank pulley etc.
Offline klp1569
  • hixson, tn
« Reply #5 on: March 01, 2011, 07:25:51 PM »
I tested the wire and the light came on, so it looks like it is receiving the signal from the switch. Still nothing from the starter. What would be the next possiblity? Thanks again for the suggestions and help.
« Reply #6 on: March 01, 2011, 07:39:40 PM »
Speaking from personal experiance, a "new starter from Autozone" doesn't always equal a "good starter that actually works."
Offline klp1569
  • hixson, tn
« Reply #7 on: March 01, 2011, 07:53:58 PM »
True and I did think of that. The only problem is that it had a bosch starter on it before the replacement and the 'problem' and that was doing the same thing after the pop. Unfortunately, I didn't test the wire first. Thanks...
« Reply #8 on: March 01, 2011, 08:25:09 PM »
you should be able to test the starter in or out of the car by putting positive to the small terminal in the car or use jumper cables outside of the car
« Reply #9 on: March 01, 2011, 08:26:27 PM »
you should also check the ground wire to the engine, probably on one of the transmisson bolts
Offline klp1569
  • hixson, tn
« Reply #10 on: March 01, 2011, 09:51:25 PM »
I will check the ground wire tomorrow. Is there a 'jumper wire' that you buy or do you make one? If you make one, what type/guage wire do you use and do you just make contact with the positive post on battery and the bare terminal on the starter? Thanks.
« Reply #11 on: March 02, 2011, 06:39:45 AM »
just make a jumper wire with a decent size wire, 2.5 metric guage, or i have just used a screw driver to jump from the posirive side of the starter to the terminal, as i said this is not the perferd method
« Reply #12 on: March 02, 2011, 08:22:48 AM »
Yeah, that... I have fixed a BUNCH of problems on VWs with ground issues.   8)
« Reply #13 on: March 02, 2011, 09:09:29 PM »
Is it a manual or an automatic transmission?  And did you replace the battery after the "pop" or is it still in the car?
Offline klp1569
  • hixson, tn
« Reply #14 on: March 02, 2011, 09:22:28 PM »
I didn't get a chance to use a jumper today or check the ground, will try tmorrow and update with the results. The Cabriolet is a 5spd and I did not replace the battery. I had taken it out when I pulled the starter and it sat out for a few months. I put it on a charger before putting it back in. Thanks again...
