Topic: new and stumped  (Read 3127 times)
Offline rickarmann
new and stumped
« on: November 04, 2012, 08:11:27 PM »
hey I'm new to this forum and fairly new to chattanooga.  i have a 70 beetle conv.  that i just rebuilt (from a good shortblock) and i have got it all together but i am having trouble tuning it.  1600 D.P.  valves are set -.006, points in distributor set -.016, timing set approx. 6-8 BTDC.  Initial settings on carb 34 pict 3 set 2 and 1/2 turns on bypass screw and mixture screw.  i can get it to start up and run for a minute with my hand on the carb but i can't get it to idle on its own.  any suggestions?
Re: new and stumped
« Reply #1 on: November 05, 2012, 11:44:24 AM »
The first thing to check if it won't idle is the idle cut-off solinoid on the side of the carb.  Today's gas seems to start turning to varnish and gumming things up in just a few weeks.  If the idle cut-off is stuck closed, it won't idle.  Make sure it clicks when you put power to it.  Even if it clicks, it might not be a bad idea to pull it out and give it a good shot of spray carb cleaner.
Re: new and stumped
« Reply #2 on: November 05, 2012, 12:08:07 PM »
All that Zen said Plus, Ck your  intake boots, Intake manifold at the heads, carb base gasket and the little brass screw- out jet on the right side of the carb by the choke. Take it out and Blow through it with some carb cleaner or better yet compressed air. Just remember we are making suggestions based what info you shared. Hope it helps.
Re: new and stumped
« Reply #3 on: November 05, 2012, 02:41:10 PM »
Sounds like you are needing to choke it to get it run, which means lake of fuel to the intake. Zen's suggestion about the Idle Cut-off Solenoid is spot on for one that won't idle. I would also check the carb and blow out all the passage ways. The other things that you might ought to check are the fuel filter and fuel pump, it could just be that the carb isn't getting enough fuel!
What is the status of the carb? Did you use the proper fuel pump push rod for your fuel pump? Too short and it won't hardly pump.
The fact that in runs with the hand shows that the ignition is close enough that it should at least run rough for long enough to warm it up and tune it in.
Re: new and stumped
« Reply #4 on: November 05, 2012, 02:41:44 PM »
Welcome to Chattanooga, and to our club!
Re: new and stumped
« Reply #5 on: November 06, 2012, 04:16:01 AM »
Leaky stuff like manifold to heads,  the rubber boots. How the carb seats to the manifold.  I never got my carb to idle.  I was just able. To slow how long the engine would run until I had to tap the gas pedal.  If you can start the engine, give it rev...  Jump Out the front seat.  Run to the back of the bug and. Flick the throttle. Before. It dies.  Your doing well..   Sc
Re: new and stumped
« Reply #6 on: November 06, 2012, 08:10:50 AM »
Speaking of fuel pumps, If you used the later "angled pump" and the older long push rod, that fuel pump is history more than likely.
Offline rickarmann
Re: new and stumped
« Reply #7 on: November 06, 2012, 10:01:45 PM »
thanks for all the suggestions.  I have an electric fuel pump set up near the gas tank something like 2psi.  when i was rebuilding it my old pump used the longer or shorter rod i forget so now it is electric.  it pumps a steady flow of gas out of the hose when not attached to carb.  The carb is a bocar that was put on the car and used for 500 miles or so and then sat for 5-6 years till i decided to revive (hopefully) my bug. i rebuilt the carb myself and put a new shut off solenoid on it. I will check for the click.  intake boots are new, all vacuum lines are plugged i believe.  will check the carb to intake gasket.  i will also have to check the screw mentioned on the right side of the carb.  i may also find a shop to professionally rebuild the carb as it sat a long time and i am not confident of my rebuild.
