Topic: Noobs trying to find the t-stat or a hole in the ground...  (Read 5520 times)
Offline green1
  • Always on the road.....
« on: January 06, 2011, 01:40:53 PM »
When we say we have no previous mechanical experience, we mean NO previous mechanical experience...
That being said, we want to learn now on Myrtle.  Now, since she is freezing from lack of heat and this week looks bad, we need to try to fix this if we can.  I lost my job right before Christmas, so we have a renewed committment to learn to do these things ourselves.  Nothing like inspiration, right?!
The issue - Her fan blows, but there's no heat until the temp reads about 190F.  Then, about an hour later, you're comfy, but never hot.  The other issue is air is blowing from every vent no matter which position we select.  We also have the foam insulation blow out of the vents at us periodically.  If we close the vents, there is whistling, so we know air is still getting through.
Is the issue two-fold?
1)Is the thermostat stuck open, thereby never letting the warm air build up to be used in the cabin? Is it behind the wheel and pwr steering pump?
2)We understand there is some weather stripping located somewhere that has obviously decayed over the years and needs to be replaced.  We just can't find any documentation on this so we know how much disassembly is needed to get to the affected area.  Any help?
Re: Noobs trying to find the t-stat or a hole in the ground...
« Reply #1 on: January 06, 2011, 02:20:39 PM »
I am by no means an authority on heaters or even water-cooler VWs for that matter, but I did some quick searches online and it appears that the heater core has engine coolant running to it continuously and that they used little flapper doors to block the air movement over the heater core (small radiator). The controls will open the doors and let airflow go through the heater core and into the ducts to the car.
I also read that the doors had holes on the (!??!) that are covered in foam. It appears that others have had problems with the foam coming off and the leaking air mixes too much cold air with the heated air. Some folks recommended duct taping over these holes, others said foam with a sticky side can be found at ACE hardware.
I will repeat that I have never taken a heater apart, let alone a water cooled VW heater. I online know what a quick internet search showed me.
Good luck! and maybe the true authorities can weigh in.
Offline green1
« Reply #2 on: January 06, 2011, 03:17:29 PM »
So, might that mean that there's no connection to the t-stat?  ???
We have been told a littttlllle bit about the door flaps, but trying to find clear instructions as to how to get to them to see if this is within our skill level.  If we have to take the whole dash apart, I'm not sure.  We want to, but not at the expense of breaking soem delicate plastic and having to replace something unnecessarily.
Thanks, Nick.  Hopefully, you're right and some others will chime in. :P
Offline green1
« Reply #3 on: January 06, 2011, 03:35:42 PM »
Can someone tell me what they think of this information?
http://www.veedubz.co.za/tech/VW%20Haynes%20Mk3/HEATER%20SYSTEM.pdf
« Reply #4 on: January 06, 2011, 03:50:56 PM »
Take a peek under the hood and see if you can see where the thick hoses run through the firewall. I would imagine they are more to one side or the either. Look under the dash where you see them go through and you will probably see plastic duct work- or a cover panel. I don't blame you for not wanting to risk breaking plastic, but under dash parts are probably more likely to be secured withs screws than snap on tabs, so you should be able to see a way to get in there.
Looking at the link, page 4 appears to hold most of your info with the diagram. It looks like the majority of the unit is above the passenger's feet with the heater core/ control flaps behind the radio area. Id peek up there and see what you can see. The actual repair is rarely the trouble; its usually getting there that takes hours of work. Slow and steady
And if you do have to do any disassembly, check the obvious ways in first, like ashtrays, glove box (or do ya'll have a glove box?) or other things that might just pop on/off. These items usually hide the first screws you have to remove.
Offline green1
« Reply #5 on: January 06, 2011, 04:01:20 PM »
We found that out just doing the litle bit with the climate control panel and the lighter bulb.  You'd have thought Shannon and MacKenzie found the cure for cancer when they came back in and everything was working.
Mark
Shannon just found a service manual, hopefully.
« Reply #6 on: January 06, 2011, 07:14:10 PM »
i would not attempt to get into the dash yourself,  check the hoses going to the heater core at the firewall when the car is hot, if both hoses are similar temps and hot then you have coolant to the heater core and the problem could be the blend door in the heater box,  also i have seen poeple mix up the cables when the put the controls back in and the blend doors do not work right, taking the heater box out that contains the blend door is a task
« Reply #7 on: January 07, 2011, 08:20:43 AM »
All of what Travis said.  I got a message from you while we were in Nashville over the holidays, but have been sick, Shannon... hadn't called anybody back the last week or so.  I would caution against removal of the dash yourself, airbag removal, lots of stuff that is tricky coming out (not to break) and going back together (so it will work after the fact)... it's time consuming even for someone who has been in there a number of times, much more so for a first timer.... all that effort and time for about $5 worth of crumbling insulation, i am pretty sure that is the whole problem.  You should feel warm air of some kind as soon as the needle starts moving on the temp gauge.
Offline green1
« Reply #8 on: January 07, 2011, 08:28:15 AM »
Thanks everyone!  That's why we came here to ask.  We wanted to know if this was something very simple, or way beyond our skill level once we got into it and had no way to return.
Rick, no worries.  We had wanted to do that stuff ourselves, I just didn't want to break anything in the process.  Maybe we need to stick with learning how to do oil changes and simple maint. first.  ;D
This vent stuff, however, I think I'll leave to you when you have time.  Hopefully, Mark will be working again by then and the timing will work out.  In the meantime, there's always the Carhartt option.  :P
