Topic: 97 jetta won't start after driving a while  (Read 3045 times)
« on: August 03, 2010, 08:55:48 AM »
working on a vr6 jetta that won't start will turn over, then once it does start it sputters and after a few restarts will run fine for a while,  no faults in the sytem just replaced the coil wires and recent plugs aaa engine.  just happens when the engine is really hot
Re: 97 jetta won't start after driving a while
« Reply #1 on: August 03, 2010, 07:41:08 PM »
What's the fuel pressure look like when it's having the starting problem?
« Reply #2 on: August 03, 2010, 07:47:07 PM »
fuel pressure and maf were gonna be the next thing i checked,  drove it with the scan tool and looked at mvb 3 and the readings looked pretty normal but the car was not acting up
« Reply #3 on: August 05, 2010, 06:53:57 PM »
Fuel pressure is at 2.5 bar but I have not gotten it to act up since I have been checking
« Reply #4 on: August 05, 2010, 08:19:15 PM »
Check MVB 125, that should be the fuel trim reading on a '97.  Start the car from dead cold, well as cold as it can get in this weather, and keep an eye on the intake air and coolant temp sensors to make sure one of them doesn't have a dead spot in it - you may have to resort to the DSO.
Also, do the residual pressure test in ELSA, that'll let you know if you have an injector that's leaking down or if the check valve in the pump is bad.  If it turns out to be the pump check valve, you don't have to replace the pump.  You can get an external check valve to install in the fuel line.  There used to be a tech bulletin that had the info so check in ELSA in group 20 and see if it's still there.
« Reply #5 on: August 05, 2010, 08:36:24 PM »
Wow,
Now I know why I like my aircooled stuff...
« Reply #6 on: August 10, 2010, 01:19:22 PM »
group 125 feild 2 3.9 %  field 3 -2.3 %  temps looked ok while driving,   car did not mess up while i was driving though, i am going to hook the fuel gauge back up and drive it some more.
« Reply #7 on: August 10, 2010, 07:58:47 PM »
Wow,
Bah, all that is easy to do, you don't even have to pop the hood until you get to the fuel pressure check.  It beats rebuilding a carb any day.  ;D
Oh, and Travis, take a fuel sample and make sure it's not polluted with ethanol.
« Reply #8 on: August 14, 2010, 08:34:47 PM »
still messin with this jetta,  i was driving it yesterday and it would try to cut out while i was driving it.  Going to try to hook back up the fuel pressure tester while it is acting up
