Topic: 92 Jetta gl starts and dies  (Read 3447 times)
« on: February 24, 2010, 10:08:41 AM »
I have a 92 jetta gl that starts and dies, so i thought i would be the first to start this new thread.  it has fuel pressure, spark etc,  i unplugged one injector to put a noid light on and the car runs idles etc and the can plug the injector back in and the car will die
Re: 92 Jetta gl starts and dies
« Reply #1 on: February 25, 2010, 07:03:20 AM »
Is the car Digifant?  If so, make sure that the injector harness isn't shorted out and that none of the injectors are leaking.  Also, check the resistance on each of the injectors.  I don't know what the spec is but on most of the later cars it's around 15 - 20 ohms.
« Reply #2 on: February 25, 2010, 12:04:37 PM »
Since I do not own a water cooled VW, take this with a grain of salt.
I seem to remember that if one of the windings is bad on 1 injector, it will ground out all the injectors...  Sounds like your problem, pull the harness, no ground, idles good.  plug it back on / hits the bad winding in the injector, and presto no runny.
Change positions of the injectors if you can get it out w/o buggering up the seal, I bet your problem will follow the injector around.
KC - This advice is free and worth every penny you paid for it!!!
« Reply #3 on: March 23, 2010, 10:06:12 PM »
My buddy took it to rick aty r and m he found a bad ecm got a used one and got it going thanks r and m
Offline cindy
  • Harrison, TN
« Reply #4 on: March 24, 2010, 08:39:31 PM »
Rick at R&M is great!  He has worked on our son's GTI and we have taken the New Beetle to him to have some things checked out.  Great service and very reasonable on his charges and if it's something he can't take care of is not afraid to refer to someone who can fix it for you.   :)
