Topic: 1.8 turbo valve question  (Read 2983 times)
Offline agrezy1
« on: May 06, 2012, 11:24:51 AM »
so got the 01 beetle running its been sitting for 9 months changed the oil right away.question i have is seems like the upper end seems little ticky for lack of better words  ;D nothing major is there any adjustments on these engines? 1.8 turbo never fooled with these before thanks...
Re: 1.8 turbo valve question
« Reply #1 on: May 06, 2012, 12:28:54 PM »
If the oil is not changed regularly the pick up tube can become clogged and and reduce oil pressure,  I recommend factory oil filter and synthetic oil,  also the cam chain tensioner can make noise if it is worn,  I will tick for a while if it has been sitting
Offline agrezy1
« Reply #2 on: May 06, 2012, 08:49:31 PM »
hey travis can the pan be pulled in the car to clean the pick up?
« Reply #3 on: May 07, 2012, 06:17:28 AM »
Yes you can remove the pan pretty easy, just a couple of hidden bolts between the engine and transmission in little holes you have to use a long extension and a wobble to get to
Offline agrezy1
« Reply #4 on: May 07, 2012, 11:38:54 PM »
ok pulled pan tonight everything looks good couple of very small pieces of rubber in pick up tube screen but no sludge...
« Reply #5 on: May 08, 2012, 05:08:36 AM »
Use synthetic oil and drive it,  check the faults for any timing faults,
Offline agrezy1
« Reply #6 on: May 08, 2012, 10:41:48 PM »
ok all back together no problems put snthetic oil and mobil one filter all good.....
the ticking i was hearing is the fuel injectors still doing it are they suppose to sound like a sewing machine? seem little loud
« Reply #7 on: May 09, 2012, 05:59:10 AM »
Sorry,  it is kinda hard sometimes to give good advice without seeing or hearing the car,  but know you have piece of mind,  the 1.8 is a good motor if you change the oil on it,  we see so many abused,  also the timing belt is real important,  they should be changed about every 80 k or when they are shinny and cracked
