Topic: Well everyone the very first vw engine.. 1600 dp...  (Read 4640 times)
Offline 71SuperBee
  • Cohutta,ga
« on: March 29, 2005, 06:19:33 PM »
I am proud of myself. for pulling this engine. is there anyone like RET.BUGTECH that can tell me how much i have saved in labor for front brakes bearings tie rod ends and drag link and pulling the engine myself and doing the push rod tubes???? Thank you if you could RET. I really appreciate this man, he is a gift to all bug newbies...
        Aaron
« Reply #1 on: March 29, 2005, 10:02:03 PM »
Aaron,
For me, it's not all about how much you saved, it's more about "I did it myself."  I've saved thousands pulling my own engines, doing my own brakes, doing my own electrical repairs . . . But, if I had to figure in all the tools, bandaids, fire-fighting equipment (long story), and doctor bills (laying on the wet, cold ground in the middle of the winter might save you a few hundred dollars at your mechanics, but it isn't good for your health :? ) I probably should be driving a brand new SUV.
Guess I watched too many McGuiver episodes when I was a little younger.  I'd rather take a beating than pay someone that actually knows what they are doing to fix my vehicle.
Offline Bugz
  • Burlington, NC
Ret. Bug Tech
« Reply #2 on: March 30, 2005, 08:08:37 AM »
You got that right! :thumbs-up:
As are a vast number of our other members!
« Reply #3 on: March 30, 2005, 09:16:49 AM »
Ah !!  O.J.T.D.I.M.(did it myselve) This is the kind of training that no amount of money can buy.  Talk about "Newbie" Im standing here looking at a brand new MIG welder and Reinhart (faux KdF Wagen) whose body looks like a surivor from Dunkirk thinking all the while that:
 I can do this.   I  already have the Zen approved ,tried and tested safety/medical equiment at hand and the approriate gravel/mud work area. As Adm.Farragut said at the battle of Mobile Bay:  Damn the torpedos,Full speed ahead. !! :roll:  I guess I can call on Richard when I get over my head. He has replaced more pans than a hospital LPN.  :pukeright:
Offline 71SuperBee
  • Cohutta,ga
« Reply #4 on: March 30, 2005, 09:20:07 AM »
David after I get the engine and all in top shape maybe you can weld back on my rear apron. Someone already cut it and put fiber glass back over it.. I just ripped it off.. Thanks
        Aaron
Offline 71SuperBee
  • Cohutta,ga
« Reply #5 on: March 30, 2005, 09:24:35 AM »
David do you think that my head can be fixed i mean as far as taking out the bolt in the head and maybe retapping it??? then just cleaning up the heads and changin the valves? What all do you do when you work on a head??
     Aaron
« Reply #6 on: March 30, 2005, 09:28:22 AM »
Aaron, You are talking to the wrong person. You need to talk to Richard Strout. Is there anything left of the orginial apron ? You can buy a metal replacement  W/tail pipe cut outs.
Offline 71SuperBee
  • Cohutta,ga
« Reply #7 on: March 30, 2005, 09:29:48 AM »
Yes I have the whole apron just has a small gap and i mean small gap between the apron and where it was cut.. I don't want to tackle this rear apron replacement really
         aaron
« Reply #8 on: March 30, 2005, 09:43:03 AM »
Aaron , I would need to see the heads to make sure that I can replace the studs. If someone has put O.S. SAE bolts ,there may be a problem. As far as the rest , It would be routine , resurface the valve seats ,valve guides if ness. and replacing exhaust valves. No telling what someone has done when the "banged" the header on.
Offline 71SuperBee
  • Cohutta,ga
« Reply #9 on: March 30, 2005, 09:48:17 AM »
OK so what was the price on that?? I can't remeber...
I can take them off and bring them to you when i bring the tranny.. and i also need you to clean the heads if i can use them and clean the tranny if i can keep that as well. I am not sure but I think there is a leak in the tranny somewhere toward the front. Although it looks like engine oil..
     Aaron
« Reply #10 on: March 30, 2005, 10:31:55 AM »
Aaron, Around $100 incl valves. Any additional would depend on what I would have to do with the studs. I will check studs first to see if we can do anything with them. There is a weep hold on the nose cone of the tranny and over the years it will blow a little lube out. Also a little seal on the end of the shift rod that can seep. No big deal. Most all trannys will seep at these points over the years
Offline 71SuperBee
  • Cohutta,ga
« Reply #11 on: March 30, 2005, 12:20:41 PM »
good deal thanks, one more thing. can i was my engine block? I have tons of oil build up???
and if so how and what is the best way
     aaron
Offline 71SuperBee
  • Cohutta,ga
« Reply #12 on: March 30, 2005, 06:22:47 PM »
Hey there David,
   Just wanted to know for the sake of saving me some cash, soon as i get my other head back i will bring both of them to you and let you look before i go and pay 260 for new ones.. That way i save a few bucks and we are both happy.. So soon as I get them I will let you know and bring them to you and let ya see what you can do...
           Aaron
