Topic: new addition... 89 cabriolet wolfsburg edition!  (Read 8382 times)
Offline 74loaf
  • Hixson, TN
« on: August 08, 2011, 10:36:19 PM »
ok so there was a guy that I went to help out back in the wintermonths that couldnt get his cabriolet running... well I noticed last night he had it up for sale on craigslist... saying he still couldnt get it running... so I rang him up today and went over and took it off his hands...
Anyways... brought it home, and first thing took off the top of the air filter housing and moved the flap back and forth for the fuel distributor a few times... once it was moving nicely I put in a fresh battery and began cranking it... slowly but surely each time it began to sputter a lil longer than the last, until she finally idled on her own once again!
Sooo... now I need some input. Heres what I'm currently working with:
Throw out bearing is a lil noisy when off the clutch... first gear in the shift gate equals 3rd gear in the transmission.... I know the throw out bearing needs to be replaced... but the shift gate thing sounds to me like a bushing issue... what do you think? heres some pics:
and heres a video of it running... you can definitely hear the throw out bearing... but I think it has since quietened up a bit:
« Last Edit: August 08, 2011, 10:41:39 PM by 74loaf »
Re: new addition... 89 cabriolet wolfsburg edition!
« Reply #1 on: August 09, 2011, 07:05:34 AM »
good deal, the bushing will deff make a difference, they make a kit to replace them all, clean and make the shift rod coupler on the end so you can put it back in the same place, sometimes you get lucky and dont have to adjust it
Offline 74loaf
  • Hixson, TN
« Reply #2 on: August 09, 2011, 07:55:47 AM »
ok I will look for that... any idea where a good place to get that from would be?
Also when the engine is cold it doesnt want to start very well.. but once its warm it cranks right up. Would that be a cold start injector issue or maybe something else?
« Reply #3 on: August 09, 2011, 09:53:21 AM »
pretty sure mainly should carry the bushing kit, you can also find them online, the starting issue could be cuased a little by bad gas, gummed up system, air leak, i am pretty sure those things had a fuel heater on the front of the block, they are real sensitive to fuel pressure, but i am no expert, the oldest cars i see now a days are 1999.
« Reply #5 on: August 09, 2011, 09:44:45 PM »
That's the wrong shifter bushing kit for a Cabriolet.  That would work great on a Cabrio but not on the Cabriolet, which is an A1 chassis.
The A2/A3 chassis cars use the 191-798-211 kit.  You need this one - 171-798-211
http://www.busdepot.com/details.jsp?partnumber=171798211MY
And it's 3 bucks cheaper  ;D
Offline 74loaf
  • Hixson, TN
« Reply #6 on: August 10, 2011, 08:48:17 PM »
been driving it around a bit today.. seems to run alot better.. although now it idles around 1500 rpm so I'm wondering if the auxillary air valve is stuck open...
also my oil light blinks below 1500 rpm but goes off above that. not sure if thats low oil pressure or what. Oil level on the dipstick is right in the middle of the normal range and isnt that dark.
As for the shifting, I can find first and second now... although I have to push the shifter down just a bit to get to the gate for first and second... guessing thats worn bushings...
oh yea.. front end has a bad wobble at the right front wheel I believe.. its bad around 20 mph but smooths out around 35 or 40. I'm wondering if it has to do with the previous owner trying to do his own wheel bearing job.
« Reply #7 on: August 10, 2011, 09:32:10 PM »
I don't have a lot of experiance with water cooled VWs, but my Passat does not like any of the brands of oil filters that AutoZone sales.  I had all kinds of oil pressure issues when I tried to run them.  I started buying OEM filters mail order from autohausaz.com and since I started using them, I've had NO issues with oil pressure.  I can't think of the actual brand name of the filters off hand, but I'm sure you can get the correct ones locally too.
« Reply #8 on: August 10, 2011, 09:59:04 PM »
Zen is right about the oil filters, also some of them had 2 oil pressure switches, one on the side of the head and one on the oil filter stand, if one goes bad it may only set the light off at lower rpms
Offline 74loaf
  • Hixson, TN
« Reply #9 on: August 12, 2011, 09:55:52 AM »
so I drove it to the gas station last night... on the way home the radiator bypass hose popped from age... good grief that hose is a pain to replace!!!!!! spent over an hour just trying to get the lower end of the hose off...
« Reply #10 on: August 12, 2011, 11:09:28 AM »
Those oil pressure switches have different Bar values so you can not mix them up. I have truly  forgotten just about everything I ever knew about "H20 VW's thank God. There are a lot of well informed "Water Dog" tech's on here. Dubtech is one the best hands down.
« Reply #11 on: August 12, 2011, 06:48:27 PM »
Aw shucks Dave, thanks   :D
As far as your oil pressure light goes, step 1 is to go buy a factory filter, put some 30 weight in it and see what happens.  That combo cures a lot of ills.
Your oil pressure switches are low pressure for idle and high pressure for over 2k RPM, I want to say 0.5 bar and 2 bar but don't make me lie to you.  Don't get them mixed up or weird stuff will happen.
Oh, and go buy a Bentley manual for your car if you don't already have one.  The Haynes manual and the John Muir manual make good supplements to the Bentley but they shouldn't be your only source of repair info.
Offline 74loaf
  • Hixson, TN
« Reply #12 on: August 16, 2011, 08:35:02 AM »
sooooo dubtech.... how are you at adjusting CIS? I'm thinking somone has "adjusted" mine before... so I need it looked at. it idles pretty high now (1500 rpm) and I'd like to figure out everything else before just turning the idle screw. I also need a shift rod bushing (the one that goes under the car in the middle of the main shift rod shaft if you know where I can get my hands on one. I was eventually planning on getting one of those that you can find on ebay, but for now I need something to suppliment the fact that I cant find 5th gear at all.
« Reply #13 on: August 16, 2011, 11:50:34 AM »
If this the CIS I'm use to you had to use a frequency meter to plug into a plug and a good ground then adjust the fuel distributor with a 3 or 4 mm  "t" wrench. You were not supposed to touch the idle screw.
« Reply #14 on: August 16, 2011, 06:43:20 PM »
Yep, you have to have a dwell meter to adjust the CO properly.  So before you start playing with that, check for any vacuum leaks and make sure that your auxiliary air regulator isn't stuck open.  If it has one, it'll be on the back of the manifold.  It's also a possibility that the o-ring is shot on the idle screw.
As far as the shifter goes, the big bushing that the shifter rod goes through comes with a free bracket when you buy it.
It should be number 21 in this picture:
http://www.wagenstad.com/index.php?modid=199&page=7-122-00
And it's available here:
http://www.busdepot.com/details.jsp?partnumber=171711194G
For better shift feel, update your shifter rod to the later A3 chassis one:
http://www.busdepot.com/details.jsp?partnumber=1H0711183
