Topic: My Rabbit  (Read 41115 times)
Re: My Rabbit
« Reply #105 on: June 25, 2013, 04:28:13 PM »
Wha?
What did I do...
Oh look a Green Bunny...
What were you saying?
You gott'a love ADDHD ;) ;)
Offline DieselDoc
  • Chickamauga, GA
    • S&P Automotive
Re: My Rabbit
« Reply #106 on: June 29, 2013, 07:43:33 AM »
Russ I don't know how I missed a page an a half of updates on your car. But you seemed to have it sorted. The solenoid is indeed the reason your car wouldn't start. It's the only way to shut that engine off, it has a little electromagnet plunger that drops when the power is off, they go bad occasionally, it's a fancy upgrade from a cable to a shut off valve like my tractors have.  Glad it was a free learning experience.
Re: My Rabbit
« Reply #107 on: June 29, 2013, 09:27:03 AM »
Free indeed! Yesterday I got my little battery terminal brush and cleaned both the posts and the cables. They had a little bit of corrosion on them. Then I tightened them all back up and haven't had any problems since.
Re: My Rabbit
« Reply #108 on: August 20, 2013, 11:32:21 AM »
Not much to report lately.
Coming up on 1 year of ownership. I'm happy with the progress it's made. I've put close to 8000 miles on it since last September.
Re: My Rabbit
« Reply #109 on: August 23, 2013, 09:58:02 AM »
No news is good news!   :D
I still love this little car, Russ.
Re: My Rabbit
« Reply #110 on: August 23, 2013, 02:07:51 PM »
Thanks! I really like it too. Great little runner for around town and commutes. Some guy tried to buy it from me in the Bi-Lo parking lot the other night, haha.
Re: My Rabbit
« Reply #111 on: September 23, 2013, 11:58:43 AM »
So lately she is not wanting to start. All the lights come on when you turn the key, but no turning over. I replaced the ignition switch and I think it helped but it's still intermittently not starting.
From what I've read, it could be the stupid seatbelt ignition lockout thing. It's not supposed to start unless you have the belts buckled so maybe that relay has gone bad. Seems like some people have bypassed it with a jumper wire so I need to start looking at that.
There is a definite correlation between the buzzer and the ignition. When I turn the key and hear the buzzer going off, it won't start. No buzzer though, and it starts right up. Anyone have experience with this?
Re: My Rabbit
« Reply #112 on: September 23, 2013, 12:31:49 PM »
I had trouble out of the seatbelt ignition lockouts on Joy's 75 convertible and Justin's 74 Super Beetle.  Both of them had been bypassed by previous owners, but what they had done was pulled the realy and wrapped a stripped copper wire around the main input and output power terminals.  I guess it worked for a while, but over time, temperature changes, vibration and humidity got to the connection and they started loosing contact intermitantly.  After a couple of years of intermitant problems on both of them, I finally figured out what the problem was on Joy's convertible.  I removed the two main power wires going to the relay from the fuse box and connected the directly together.  I was able to cut about 2 feet of wire out of the circut and I twisted the wires together, soildered them, and covered them with a piece of heat shrink tubing.  Promblem solved.  I figured I'd try it on Justin's 74.  Fixed it as well!  I know you have a water-cooled diesle engine in the front of the car, but I would bet the wiring for the seatbelt relay is practically the same.  If it is, take the relay out of the circut.  That may not be your problem, but at least you will know.  And if the relay is still intact and it's not giving you a problem now . . . give it time and it will.
Re: My Rabbit
« Reply #113 on: September 24, 2013, 12:02:21 PM »
I don't have a Mk1 Bentley, but I've researched enough now to where I think I can find the seatbelt interlock relay and jumper the terminals. Hopefully that should let me start the car!
Re: My Rabbit
« Reply #114 on: September 26, 2013, 08:01:02 PM »
Well it's definitely the interlock relay giving me problems. It's a big double relay above the fuse box. I was able to jiggle it enough until the car started, but this is also the source of my seatbelt light coming on all the time, not to mention the awful buzzing noise it always makes. Where can I get a replacement, or maybe better yet bypass it so my car always starts?
Re: My Rabbit
« Reply #115 on: September 26, 2013, 10:33:39 PM »
The way I bypassed it on the two Super Beetles I've had with it was to pull the two heavy gauge wires out of the panel and soilder them together.  If you don't want to remove the wires from the panel, you might be able to make a jumper with two spade connectors and short piece of wire, remove the relay and plug the jumper across the two power terminals, but I don't have a clue what else that relay does on Rabbit.
Re: My Rabbit
« Reply #116 on: September 26, 2013, 10:46:35 PM »
There's a few things I need to happen.
1) Turn off the seatbelt warning light in the dash. I always wear my seatbelt and I resent being told it's not on.
2) Make the buzzing noise stop. This is getting really annoying, nearly every time you put in the key it goes off. And sometimes you can be driving down the road and the thing will just start buzzing.
3) Allow the car to start every time, I guess that's the "big" one.
All of these could be fixed with a known good relay I think. If I could locate one. If not though, I'm not opposed to straight wiring some of the connections. I've removed the original shoulder-only belts anyways and replaced them with traditional three point belts. I doubt anyone would be interested in returning the car to stock so much that they'd want the original passive safety restraints and interlock relay in place.
So I'd need a schematic of the relay pinouts in order to know what to jumper to bypass it and fix all three issues above. I'll start searching for one tomorrow.
I don't have a manual, but I do have a Popular Mechanics book on the Rabbit from the 80s. It does have a section on the seatbelt interlock system, so I looked it up. The last line: "Have it checked out by a professional mechanic. It is illegal to bypass the interlock system." ::)
Re: My Rabbit
« Reply #117 on: September 26, 2013, 11:15:58 PM »
Barney Fife is dead . . . I wouldn't worry too much about the legal issues.   ;)
Pull the relay out and look at the pins.  Are there two that are larger than all the rest?  If so, leave the relay out and make a jumper with a short piece of wire and two spade connectors.  Jump out those two terminals.  That "should" solve the starting problem . . . I would think that it would also stop the buzzing (if the buzzer is in the relay or fed by the relay).  The seat belt light . . . I don't have a clue if it would stay on or go off if you remove the relay.
Re: My Rabbit
« Reply #118 on: September 28, 2013, 02:34:27 PM »
Well that turned out to be really simple. Like you said Zen, I pulled the relay and observed the terminals. There were two larger wires which I presumed to be going to the starter. I made a small jumper using some spade connectors and plugged it in. It starts!
The buzzer was built into the relay as well, so it no longer goes off. And my seatbelt light is out as well. So that accomplishes all three things!
Re: My Rabbit
« Reply #119 on: September 28, 2013, 03:18:04 PM »
 ;D  What's the old saying . . . "Even a blind pig finds an acorn every now and then"  Glad I could help.   8)
