Topic: My new eurovan  (Read 15546 times)
Re: My new eurovan
« Reply #30 on: March 21, 2012, 02:42:26 PM »
Installed wiring to the transmission and now it dies when you put it in drive
Reverse and all the low gears as well?
Re: My new eurovan
« Reply #31 on: March 21, 2012, 03:29:10 PM »
No reverse is ok,  guess I will go back and check the splice and make sure no wires were crodsed
Re: My new eurovan
« Reply #32 on: March 21, 2012, 06:08:33 PM »
Check the faults, let's see what ya got.  With the state of the wires it's possible that it cooked the TCM or the solenoids in the valve body.
Re: My new eurovan
« Reply #33 on: March 21, 2012, 08:38:08 PM »
Would you check the faults using the 1551 with the blue and white wire?
Re: My new eurovan
« Reply #34 on: March 21, 2012, 08:44:33 PM »
The wires were missing the insulation like it had disintegrated, it is possible they were shorted, they were not plugged in  when I drove it home,  I also replace the selector switch,  but it had the wrong suffix,  correct part number,  the original one was leaking
Re: My new eurovan
« Reply #35 on: March 22, 2012, 05:14:22 AM »
Yep, or there should be an adapter for the newer scan tools.  Check here: http://www.ross-tech.com/vag-com/cars/dlc.html  The Eurovan is the 5th one down.
Re: My new eurovan
« Reply #36 on: March 22, 2012, 11:14:31 AM »
Going old school,  got the 1551 working on the van,  and now for some wiring diagrams
Re: My new eurovan
« Reply #37 on: March 22, 2012, 01:01:41 PM »
Solenoid 1 and 2 open circuit
Re: My new eurovan
« Reply #38 on: March 22, 2012, 01:30:35 PM »
Archives
Re: My new eurovan
« Reply #39 on: March 22, 2012, 01:42:21 PM »
Faults
Re: My new eurovan
« Reply #40 on: March 22, 2012, 03:41:23 PM »
ouch.
Re: My new eurovan
« Reply #41 on: March 22, 2012, 04:44:16 PM »
ouch.
That just means its an open circuit, not necessarily a bad solenoid, right? Seems reasonable since the wires were burnt.
Re: My new eurovan
« Reply #42 on: March 22, 2012, 06:52:04 PM »
You should be able to check the solenoids with a meter.  Disconnect the round connector on the transmission and check for continuity between power in (Pin 1 on the diagram, it's hard to read though) and the other wire for the solenoid in question.
My money is on a bad valve body conductor strip which also happens to include the other end of the round plug you just replaced.
Oh, I think I've got an old multi-function switch from a Eurovan laying around, I'll see if I can dig it up.
Re: My new eurovan
« Reply #43 on: March 22, 2012, 07:02:17 PM »
I found a couple of wired that did not get crimped well,  I used to large of connectors,  so I redid it and get one fault and the car still dies when I put it in gear,  the fault now is for Solenoid wires shorted together,  time to check the wiring harness to see if it is shorted together some where or maybe it is the foil strip in the trans
Re: My new eurovan
« Reply #44 on: March 22, 2012, 07:03:37 PM »
I was praising you today going though the old books and finding the eurovan manuals and wiring diagrams
