Topic: Greg's Rail  (Read 8084 times)
Offline Aircooled Werk
  • Ringgold, Ga
    • Aircooled Werk
Greg's Rail
« on: April 28, 2013, 09:00:30 AM »
Transaxle finished! On to the engine because rings are bad!
Re: Greg's Rail
« Reply #1 on: April 28, 2013, 10:56:58 AM »
Tony, I'm sure you checked the clearance for the 12 volt flywheel in that swing axle bell housing along with the conversion 6V to 12V starter bushing. Right ?? Just checking ;D
  If you have a problem with that, let me know. I have a little trick I'll share with you. I have done this many times.
Re: Greg's Rail
« Reply #2 on: April 28, 2013, 12:29:04 PM »
I've always heard just bolt it up tight and left the flywheel self clearance. Steel > aluminum
  • Ringgold, Ga
    • Aircooled Werk
Re: Greg's Rail
« Reply #3 on: April 28, 2013, 12:59:53 PM »
Someone has already clearanced the housing
Re: Greg's Rail
« Reply #4 on: April 28, 2013, 04:01:47 PM »
You bolt it up a little bit at the time. You don't just lock it down. The starter will reach the fly wheel . Spin the engine over until it quits protesting ,tighten it a bit more and repeat.  Then take the starter off and clean all the "stuff' out of it. Piece of cake.
  • Ringgold, Ga
    • Aircooled Werk
Re: Greg's Rail
« Reply #5 on: April 28, 2013, 09:10:15 PM »
The boots are not tightened yet. I am waiting to fit the tranny in the rail, then turn them 90 degrees so the joint will not be vertical. Not happy with the boot fit. They are not that German OE fit!
Re: Greg's Rail
« Reply #6 on: April 28, 2013, 10:44:42 PM »
I was going to say that looks like a rookie mistake...
Re: Greg's Rail
« Reply #7 on: April 28, 2013, 10:53:07 PM »
I never liked those boots either.
Offline gpeterson
  • fto
Re: Greg's Rail
« Reply #8 on: April 29, 2013, 05:56:13 PM »
Sweet
  • Ringgold, Ga
    • Aircooled Werk
Re: Greg's Rail
« Reply #9 on: May 08, 2013, 08:03:52 PM »
Engine finally going back together!
« Last Edit: May 08, 2013, 10:01:12 PM by takeflight »
Re: Greg's Rail
« Reply #10 on: May 08, 2013, 09:31:23 PM »
Man ! You have a strange work bench or you love working on VW's on the side
« Last Edit: May 08, 2013, 09:33:35 PM by Ret.Bugtech »
  • Ringgold, Ga
    • Aircooled Werk
Re: Greg's Rail
« Reply #11 on: May 08, 2013, 09:58:16 PM »
Yes sir, I do enjoy my side job. As usual, waiting on parts that were suppose to be shipped last week and just shipped today!
« Last Edit: May 08, 2013, 10:02:37 PM by takeflight »
  • Ringgold, Ga
    • Aircooled Werk
Re: Greg's Rail
« Reply #12 on: May 24, 2013, 04:51:32 PM »
Finally!!! The finished product ready for exhaust and installation in the rail!
Re: Greg's Rail
« Reply #13 on: May 24, 2013, 08:22:00 PM »
WOW!  If it runs half as good as it looks it will be a sweet running engine!   8)
  • Ringgold, Ga
    • Aircooled Werk
Re: Greg's Rail
« Reply #14 on: May 24, 2013, 08:38:27 PM »
That's what I said!
