Topic: 1972 AutoStick Unstuck!  (Read 12281 times)
Offline 71SuperBee
  • Cohutta,ga
« Reply #30 on: September 29, 2008, 07:08:17 AM »
Quote from: "ASBug"
Where are you?  I'm just at the Catoosa / Whitfield line.
Are you in DOWNTOWN Cohutta or do you live in the suburbs?
 :D
I am in the northern parts lol...... :lol:  not really sure where i am most of the time!
Offline SpyCarHippie
« Reply #31 on: September 22, 2009, 10:39:53 PM »
I'm looking at your vacumn hoses.  Your carb is not for a auto-stick,but not to fear.  The vacumn line on the backside of the dist is for vacumn retard. (early emission control) Block that one off . You can leave the port open on the vac.unit. Take the vac.hose from the "shift solinoid and plug it on the front of the carb. This may help smooth out some shifting. The vac.hose from the front of the vac. unit to the side of the carb is correct.  Re-check your timing. I'm sure it moved.
    Be sure to block off the port on the intake manifold. If all this doesn't help anything, put it back like it was and blame it on the non-auto-stick carb. :lol:
Sorry to re-hash an old post. I'm new here and I would appreciate some clarification. My Ghia has the same set-up. I'll eventually fix it right but for now anything that would smooth out the shifting would be great.
I'm not sure I get this part...
"The vacumn line on the backside of the dist is for vacumn retard. (early emission control) Block that one off . You can leave the port open on the vac.unit. Take the vac.hose from the "shift solinoid and plug it on the front of the carb."
Are you saying that the 3mm line from the distributor to the lower part of the carb can be removed? Then block off the port in the lower part of the carb and leave the port open on the distributor? When you say "shift solenoid" are you talking about the control valve?... 3mm line from the control valve to the front of the carb? Am I getting this?
Sorry if I'm not using the right terms. I've been reading up on the autostick and I'm aware that I have the wrong carb and that there's a fix for it. I'm a little scared to go drilling holes in my carb so if this technique will help -even a little- I'll give it a go.
I'm not a great wrench but I am mechanical (tool & die for 30years) and I'm eager.
Any guidance would be appreciated.
Dave
« Reply #32 on: September 22, 2009, 11:32:27 PM »
ASBug's autostick had a DVDA (duel vacuum, dual advance) distributor.  One side of the vacuum pod was for advacing the timing, the other for retarding it.  Adding the retard side to the unit was an early attempt at emmisions control.  Because it made tuning the engine super hard, the retard side was typically plugged off and the distributor was ran as a SVDA (single vacuum, dual advance).
Distributors and Carbs were designed as a package.  When one piece of the system gets replaced with a part that wasn't specifically designed for the system, things get a little tricky.  Remember that all vacuum is not created equal.  Size and location of the vacuum ports make a huge differance in the amount and timing of the vacuum.  Some vacuum ports pull more vacuum when the engine is under a load with the trottle opened, some pull more vacuum when the engine is ideling.  Some pull a little bit of vacuum, other pull a lot.
I know all that stuff, but I don't have a clue what goes where.  I just know it matters.   :D  If I need to know which port to hook which line to, I just ask Ret.Bugtech . . . He's been working on these critters since most of us were in diapers and he knows his stuff.  Casey (ASBug) is well versed in autosticks.  Between the two of them, you should have your Ghia shifting smoothly in no time!   8)
