I'm looking to sell off this set up I have been putting together for the last year. It's almost everything needed for programmable electronic fuel injection for ANY engine 1 cylinder to 12. I have a customized CB crank pulley with the 36-1 trigger wheel cut into the back and a crank sensor and bracket to go with it. This will run a Ford EDIS ignition and ditch the distributor, also included is the Quad Spark module so you can run COP or CNP and not a single coil pack. Megasquirt, Jim stim, assembled cable and relay board, Quad Spark module, crank pulley, crank sensor and bracket, and distributor plug. All for $600.
