Topic: FV Road Atlanta - Qualifying  (Read 3601 times)
« on: July 25, 2004, 10:14:42 AM »
OK Zen, Been there ,done that many times, but you didn`t tell us where Anthony qualified for the race and if the FV was performimg the way it should. I`m going to take away your "Pit Tootsie" paddock pass if you don`t do better. 3 dudes and no info ? What kind of deal is this ? Did you guys stay for the BEER PARTY ?
« Reply #1 on: July 25, 2004, 05:25:13 PM »
OK, it was my first race, it was HOT.  Not just HOT, it was REALLY, REALLY HOT.  I was trying to take it all in on about 2 hours sleep . . . so, Anthony qualified . . . what place?   ??? well it wasn't first . . . and I don't think it was last . . . there were more than 3 cars in his group, so . . . well, it wasn't first and it wasn't last and Anthony seemed to be fairly pleased with his position for the Sunday race.  He also seemed to be pleased with the way the V was performing.  All I can tell you for sure is when he came into turn 1, I only had a second or two to find him in the view finder, focus and snap a picture . . . I can't say for sure if Anthony thought he was fast, but when your trying to snap his picture, he was flying!
One bit of info I CAN pass along . . . after the qualifying round, all of the cars in his group were sent to impound for a random check . . . they didn't find anything wrong with Anthony's V.  One of the "scruteneers" (I think that's what they had on the back of their shirts) suggested that Anthony add a valve and carry a piece of hose so that if they ever wanted to check his fuel, they could get a sample from outside the frame of the car.  After explaining his fuel cell set up to him about 20 times, the guy finally realized Anthony's  V already had what he was asking for.
Other than that, I can't tell you much . . . except it was HOT.  It was a lot of fun.  Maybe next time I'll have at least 4 hours of sleep the night before and can take in a little more than I did this time.  One thing for sure . . . next time I'm taking a cooler full of ice water!  Did I mention it was HOT? ???
« Reply #2 on: July 25, 2004, 06:09:49 PM »
OK , You are forgiven this one time. Hot ? It never gets hot at R.A. . It just gets VERY,VERY.VERY warm. You never have to warm up your tires and your oil  stays at operating temps at all times. Neat huh ! :D
« Reply #3 on: July 25, 2004, 07:47:34 PM »
Hi, all.  Got back just in time for the rain and shoved the Vee in the garage ASAP.  I qualified 3rd, about .5 behind the purple car I diced with the whole time.  If the weather bothered you, you should have come out Sunday.  Overcast and just into the 80s by race time.  Got a good start and was into second by turn 1, but spun on the track in 3 and lost a position.  Although the car was "loose" the whole day, I should have known better.  Sometimes it's hard to think "careful" when you're right behind the leader!  I got a good look at the nose of the Vee right behind as I spun 360 degrees.  (Afterwards, I told Shannon I was trying to read his stickers.)The car was kind of a handfull on a pretty slick and dirty track (maybe too much rear camber.  My inside rear tire temps were pretty high)Other than needing a suspension adjustment, the car did well, and I turned some times faster than qualifying, partly out of anger for my mistake!  Finished third and drove it onto the trailer, so can't complain.  The Bus barely broke a sweat on the way home!  Thanks to those who came out and to those who couldn't but sent good vibes my way! :)
« Reply #4 on: July 25, 2004, 08:23:11 PM »
The next event is Labor Day weekend at Atlanta Motor Speedway.  I'll post details as the region gets them straight!
« Reply #5 on: July 25, 2004, 10:36:21 PM »
Hey, Good show!!!!! I wish Linda and I could have been there. Did the tranny lube make any difference that you could tell? Any leaks?  We are happy you had a safe race.
   Press On !!!
« Reply #6 on: July 26, 2004, 07:25:19 PM »
Yes, for the first time, I didn't have to put a cardboard "diaper" under the car in the paddock!  It didn't leak, and did pull a bit better on the straights.  I nearly redlined by turn one and gained about 100 RPM on the back straight by the top of the second rise.  Thanks for the suggestion, David!  The car bit very well going into turns, and the front tire temps were pretty consistant across the width, but the rears were around 20 or 25 degrees hotter on the inside than the middle and outside, and I was doing a lot of oversteering, both into and out of corners, especially at low speed (turns 3 and 7).  I seem to have a bit more camber on the rear than the other guys (about 7 degrees neg.) Too much???  High speed was better and I scared myself a couple of times dancing through turn 1 with just a tap of the brakes!  My best times were 1'54s, (remember the new chicane at the end of the back straight) about 1.5 seconds off the lead car (a 2000 year-model Citation)
David, any suggestions on fixing the oversteer?  It was also suggested to go for stiffer front shocks, and then there's the camber, which my gut says to adjust first.
« Reply #7 on: July 26, 2004, 09:01:49 PM »
I've got some pictures to upload, but I think our server is full.  I keep getting error messages.  Anyway, I didn't come back with much info . . . BUT, I did bring back pictures . . . and a couple of low quality video clips of Anthony pulling away from the pack at turn 1.  Now if I could just get them uploaded . . .  ???
Offline Bugz
  • Burlington, NC
Anthony at Atlanta
« Reply #8 on: August 24, 2004, 06:00:14 PM »
I found this photo on the SCCA's web site http://rivergate5speed.com/scca/race/rp04-10.html and thought I'd share it with everyone.
« Reply #9 on: August 24, 2004, 06:12:47 PM »
I've got some of the pictures and a couple of short video clips I took posted in the photo gallery now.  I'm still having computer problems . . . it's taking about 20 tries to get a picture to upload without something locking up.  Keep checking . . . I'll eventually get them all posted.
