Topic: Oil Leak!  (Read 3791 times)
Oil Leak!
« on: January 24, 2003, 09:35:12 AM »
When I left work yesterday afternoon, the temperature was down around 10 degrees.  I have always ran 30 weight high detergent oil year round in all of my air-cooled VWs, but this is the first time I've ran one with it this cold outside.  About 4 miles down the road I started smelling oil burning and looked in my rear view and saw nothing but smoke.  I pulled off at a Golden Gallon and popped open the deck lid . . . the entire engine compartment was soaked with oil.  It was a quart low and in the couple of minutes it took to buy and add a quart a big puddle had formed under the car.  There was so much oil that there was no way to tell exactly where it was coming from.  I headed on to the house and stopped in Noble (about 4 more miles down the road) and added another quart . . . it was still slightly below the full mark, and I didn't want to have to stop and add oil again (it was just too d*** cold!!!!) so I went ahead and overfilled it by adding another quart.  It was a little below the full mark when I got home.  So, in all I lost 3 quarts of oil in about 13 miles.  I'm not sure, but it looks like it might be coming from the oil sending unit.
My thinking is that at 10 degrees, 30 weight is about the consistency of STP oil treatment on a warm day. I think it just built up more oil pressure than the sending unit (or the oil cooler, oil cooler seals, oil pump cover gasket, or whatever turns out to be leaking) could take.  That's just a theory . . . and I'm not too fond of the idea of trying to prove it right or wrong until the weather warms up . . . but I'm sure going to consider going to a lighter weight oil during the winter from now on.
Oil Leak!
« Reply #1 on: January 24, 2003, 08:32:12 PM »
Sounds like a valid theory.  Hopefully, it's one of those leaks that will do better when your oil pressure is lower!
I'm using 5W30 in the daily beater (Neon) and 20W50 with one of those electric engine heaters in the bus, and plenty of warm-up time.  I imagine the warm-up time would be critical for thicker oil!  Also, I'm hoping for an early spring!  See you at the DOW Campout!
Oil Leak!
« Reply #2 on: February 03, 2003, 04:52:36 PM »
Just as a follow up to this story . . .
Friday I took it to the car wash and got as much of the oil as possible washed off of it . . . drove it back home to look for the source of the leak . . . it no longer exist!  It had to be due to the 30W oil being cold/thick . . . but, I can't figure out where that much oil could come from in that short amount of time without something being damaged.  At any rate, I'm NOT complaining!   :D  :D  :cool:
