Topic: Yardsale 83 Mazda RX7  (Read 10380 times)
Re: Yardsale 83 Mazda RX7
« Reply #15 on: February 26, 2011, 07:42:34 PM »
Once again I am confounded by a crazy engine.   What I thought was a drain plug. turns out to be some kind of fitting to install an additional oil cooler.  Since I thought it was just a drain plug,  I did not torque it down tight.  Thus,  when the the oil pressure built  up.  Out from the plug came a bubbling oil.  black gold, Texas tea.   SC
« Reply #16 on: February 26, 2011, 09:43:44 PM »
you don't torque the drain plugs down tight? You might be leaking from there too
« Reply #17 on: February 26, 2011, 11:14:21 PM »
-You aint right...
LOL.
« Reply #18 on: March 27, 2011, 12:24:16 PM »
the carb seems to be cutting out due to lack or fuel.  I looked into it and most folks replace the 29 year old fuel pump.  I decided it needed a good hosing.  Took the pump off.  hooked up the garden hose and did some fuel pump orifice blasting. Stuck it back to gether  and found these 2 stow aways under the storage compartments.  spooky.   rx7 did not cut out today when I drove it hard. Sweet  SC
« Reply #19 on: March 27, 2011, 02:50:56 PM »
better than the ones i found that were still ripe, in the cowl of a jetta, made for a stinky car
« Reply #20 on: March 27, 2011, 08:42:16 PM »
Yeah... it wil be a while before i forget that smell.   :-X
