Topic: Volvo doa near costco  (Read 10259 times)
Re: Volvo doa near costco
« Reply #30 on: January 07, 2012, 06:17:57 PM »
You probably are a tooth or two off, they will run but have low power
« Reply #31 on: January 07, 2012, 09:43:17 PM »
1 or 2 teeth are more than required minimum for the triangle!!   ;D ;D
« Reply #32 on: January 08, 2012, 10:09:46 PM »
Hell Far !!!!  In the Triangle they need to know what teeth are first ;D ;D
« Reply #33 on: January 09, 2012, 09:04:14 AM »
2 woards fer ya:
Dench errs.
Chew un that big boy...
« Reply #34 on: January 09, 2012, 02:53:40 PM »
By gum them dudes can chew after they pay homage to their Queen Polly Dent
« Reply #35 on: January 22, 2012, 06:22:40 PM »
so we got the SW going.  the check engine light came on.  runs ruff.  we unhook battery for an hour it runs good.  Then the check engine comes on and it runs ruff.
Today i sprayed out the throttle body and cleaned the gunk off it.  checked vac lines etc .  reset the CPU   so far it it is running great.   The codes said it was running lean  lamba something.  stay tuned    SC
