Throttle body heater bypass
« on: November 27, 2011, 02:51:59 PM »
Anyone done this ?  looks like a good idea in the summer.  SC
Cold air induction kits work pretty well but you need to do your homework first. A lot of cars have throttle body heaters, whereby coolant from the engine is circulated around the throttle body casing. The idea is to warm up the throttle body to prevent icing in cold weather. The problem is that these systems are hard-wired and don't take account of external air temperature, so even in the heat of summer, hot coolant is routed around the throttle body. This is a problem for CAI kits because you've gone to all the trouble of putting a nice kit in to suck cooler air into the engine, but at the final hurdle it runs through a 75°C throttle body which heats it up again, negating the whole point of the CAI kit in the first place. The solution to this is a throttle body heater bypass, which essentially involves pulling the coolant hoses off either side of the throttle body and patching them together with a length of copper pipe and two hose clamps. When you do this, the throttle body stays at ambient temperature and the CAI kit gets a chance to do its job. The only downside to this is if you live in a cold, humid climate
Read more: http://www.carbibles.com/fuel_engine_bible_pg5.html#ixzz1ewAKKeAK
