Topic: Smelly Alignment made easy  (Read 6799 times)
« on: January 13, 2013, 03:08:52 PM »
Since I buggered up the steering wheel position  with my 1st alignment,
 I tried to fix it better.  Used some string and everything.
  Now the steering wheel  is about even.  Still Pulls to right.  just not as bad.  SC
Re: Smelly Alignment made easy
« Reply #1 on: January 13, 2013, 06:37:19 PM »
You can get it pretty close if you use a tape measure from the center line of the tread on the back and the front of the tire and match them up
« Reply #2 on: January 14, 2013, 10:54:32 AM »
What makes you think that Smelly even has tread on his tires ?  ;D ;D
« Reply #3 on: January 14, 2013, 11:53:56 AM »
the tread has been carefully removed to reduce weight and drag for improved MPGs
« Reply #4 on: January 14, 2013, 01:20:25 PM »
Maybe Smelly needs to use 4 temp. spares pumped up to 65lb's ;D
« Reply #5 on: January 14, 2013, 04:31:41 PM »
]Maybe Smelly needs to use 4 temp. spares pumped up to 65lb's ;D
Please do not give him any ideas....
« Reply #6 on: January 14, 2013, 09:52:56 PM »
Ya.  I'm gonna try it with a level. Zip tied to steering wheel.   Maybe. That will help
« Reply #7 on: January 15, 2013, 12:23:32 AM »
I alway line the wheel up with the column trim,  much easier,  they make a tool to lock the wheel in place against the seat,  but with new laser alignment software it is no longer neccesary
« Reply #8 on: January 15, 2013, 02:40:31 AM »
Btw, what is an alignment? Is this necessary?
« Reply #9 on: January 15, 2013, 05:28:43 AM »
If you don't have a steering angle sensor you can unbolt the steering wheel and move it if you only need the steering wheel straight,
« Reply #10 on: January 15, 2013, 06:43:40 AM »
Travis.  Your Mecanicing confidence is 78 percent higher than mine.  I tried taking the steering wheel off my burned out Saab.  And broke the horn buttons off.  I was also worried the air bag would blow and give me a concussion.   The only steer wheel I'm ok takin off is Stupie beetles.   Sc
« Reply #11 on: January 15, 2013, 07:34:40 AM »
I think volvos have holes behind the steering wheel and require a long torx bit t 30 to remove
« Reply #12 on: January 15, 2013, 08:12:22 AM »
What do you mean ??   Only necessary if you want your wheels/car to go straight down the road.  On a Bug ,you center-up the sector( there are marks for that) and then adjust the toe-in, camber etc.
« Reply #13 on: January 15, 2013, 12:20:03 PM »
I feel like my beetle goes straight down the road (as long as you keep steering it straight). I have never done one of these "alignment" magic shows that everyone is talking about.
« Reply #14 on: January 15, 2013, 12:52:44 PM »
Me either. Thats somewhere around "really off or really,really off. On a std Bug its hard to tell sometimes until about 10,000 miles. I have driven old link-pin Bugs with the front end worn out and "flopping" around and the dang things would drive perfect. Go figure
