Topic: ran out of gas in chevy n ow it runs like dookey  (Read 8487 times)
« on: November 01, 2010, 07:47:32 PM »
Ok  Chevy was running great,  then I ran out of gas.  filled it up,  running real bad.   seems like it is out  of timing or something.  any ideas
Re: ran out of gas in chevy n ow it runs like dookey
« Reply #1 on: November 01, 2010, 08:11:12 PM »
Moisture and trash sink to the bottom of the tank.  It probably pulled some of it into the fuel system when it sucked the tank dry.  Put some good fuel injection cleaner in it and see if it helps.
By the way, I've found a sure way to prevent this problem . . . run out of gas at least once a month and it won't let that crap build up enough to ever be a problem.   ;)
« Reply #2 on: November 01, 2010, 08:17:40 PM »
Don't be trying to spread all your Triangle logic around in here.....  :P   :D
But, yeah, it works alright....  :-[
« Reply #3 on: November 01, 2010, 08:22:30 PM »
I did hit the filter with a hammer and the chevy ran better.  maybe it is clogged with junk .
« Reply #4 on: November 01, 2010, 08:34:56 PM »
I hear if you run some old used oil through a coffee filter and then dump it in the tank it works wonders..
« Reply #5 on: November 02, 2010, 05:19:00 AM »
White knuckle tow home last night with a short  rope.  You have to pay attention as the caboose with out power steering and power brakes.  I'm getting pretty good at this.  SC     does a 97 chevy 3100 v6 have a timing belt or a chain?.
« Reply #6 on: November 02, 2010, 06:52:53 AM »
also it is my understanding that the fuel pump is cooled and lubricated by fuel so it can damage the furl pump when you run it dry,  i have also experiences this.
« Reply #7 on: November 02, 2010, 07:59:06 AM »
Yep.  And they are very prone to crapping out.  In my years in the parts business, we sold 2-3 of these pumps for any one of anything else.  Very common failure item.
« Reply #8 on: November 02, 2010, 10:57:32 AM »
Is there some kind of ordinance in the "Triangle" say that you can't buy gas or have a working fuel gage ? The world wants to know.
    SC, Don't buy new tires . If you just stop along the road and pick up the "Gator's" that the truck's tossed, you should have a enough rubber to sew/glue to your old tires. One "Gator" should fix all your tires I would think. You do have some used thread don't you ? Maybe you should trade your Mazda for a couple of pre-tested tires. ;)
« Reply #9 on: November 02, 2010, 01:35:28 PM »
I always liked how they put these in the gas tank for ease of accessability...
« Reply #10 on: November 02, 2010, 02:13:23 PM »
No.no.no. Casey... you got it all wrong.  They put them in the tank cause they won't go bad.   ;)
« Reply #11 on: November 02, 2010, 07:40:44 PM »
One last hope I have was to unplug the battery and let the computer reset
Now the battery crapped out. Its low on water,    It is located under some stuff,  So i filled my mouth with water and got a bendy straw.  Then I kind of spit water  into the battery holes.  pretty smart!  huh?  Now the charger is doing its thing.  Stay tuned.  SC
« Reply #12 on: November 02, 2010, 07:51:50 PM »
you need an old turkey baster,  not your mouth,  i am not the safest guy out there, but not a good idea to put your face up to a battery, i am sure you had you safety glasses on
« Reply #13 on: November 02, 2010, 08:24:56 PM »
No comment....
 :D ;D :D ;D :D ;D :D ;D :D
« Reply #14 on: November 02, 2010, 08:37:57 PM »
We have got to get all his posts in print.
I have laughed more because of him than pretty much any one else I know.
We should name it "help with slow starter" or something...
LOL.
