Tech. Center
Non-VW Tech
cv joints
Topic: cv joints (Read 5159 times)
Smelly_Cat
cv joints
June 17, 2011, 08:59:27 PM »
My kid was driving the accord and it clunked and stopped. he says the front wheels dont turn any more. would a crunched cv joint somehow keep the front wheels from rolling? It was skidded up on the wrecker. front wheels locked up. SC
ASBug
Varnel, Ga
Re: cv joints
June 17, 2011, 09:53:02 PM »
Karnac, opens envelope and says "nope."
Maybe, but I do not think so.
-Deal making is done.
Re: cv joints
June 18, 2011, 07:20:16 AM »
If both wheels locked up, I don't see how it could possibly be a CV joint. It sounds like it's something in the differential or transmission.
Smelly_Cat
Re: cv joints
June 20, 2011, 07:26:11 PM »
ok we reconned the honda. no move. jacked the wheels off the road. .turnrd wheels in the air. the turned. it would roll. started it/ put in gear/ let out clutch with wheels in the air/ brack brack . worst noise I every heard. Tranny no oil.. rest in pieces honda.
Smelly_Cat
Re: cv joints
June 21, 2011, 07:55:47 PM »
just to talk
Ok accord is gone
acura had clicky axels
We replaced them today. big job for me.
learned that old honda rotors are awfull to replace. axles were easy
so instead of 4 broke cars we have 2.. accord and lumina
Life is good
SC
74loaf
Hixson, TN
Re: cv joints
July 01, 2011, 09:28:04 AM »
eh honda rotors arent hard.. at the most they are held on with a screw. the axles in my opinion are harder. oh and dont forget to bolt the long axle's brace up in there good. didnt do that once and it popped out of the tranny while driving down hixson pike... was fun laying up under it trying to pop it back in and CAREFULLY driving it home to tighten up the brace. Lesson learned.
1974 VW Bus with 2000 t4 motor and dual progressive carb
1989 VW Cabriolet Wolfsburg Edition
1998 VW GTI VR6 Ginster Yellow
certdubtech
In the Garage...
Re: cv joints
July 01, 2011, 09:52:46 AM »
^^^^ Actually, depends on the generation of Accord....
For one body style, I believe it was the one around 97-98, they used a rotor that was bolted/pressed to the hub instead of the slip on, screw aligned ones (that, incidentally they used on all the ones before and since.) I remember years ago they took a brake job from an hour to more like 3 or 4 hours, and they could be a real pain to do..... silly things automakers do.....
travisyoung
Redbank
Re: cv joints
Reply #7 on:
July 01, 2011, 12:59:47 PM »
they make a special tool for that, seen it on the tool trucks, i did one a long time ago, i am sure that i did not use a special tool, do remeber it being a pain
certdubtech
In the Garage...
Re: cv joints
Reply #8 on:
July 01, 2011, 01:48:01 PM »
One of the former Honda techs at Pep Boys years ago knew a little trick involving an air hammer, long punch and just the right spot and he could do them quickly. He would never do it while another tech was looking though....
Smelly_Cat
Re: cv joints
Reply #9 on:
July 01, 2011, 02:59:18 PM »
I took off the the whole assembly with the rotor on and went around town to the brake shops. One place put in on a press and gave up cause he thought it would ruin the bearings. the 2nd place tried to beat it into submission and gave up. They said I had to but it back on the car and they had a tool or puller that would pop it off. Cars back together. I will take it back to the shop to try again next week with it on the car. sc
drobe88
D~Town
Re: cv joints
Reply #10 on:
July 01, 2011, 06:45:47 PM »
i have seen someone mess those bearings up trying to press it, it can be done but not worth it.
Tech. Center
Non-VW Tech
cv joints
