Topic: Zen need some directions  (Read 3610 times)
65dunebuggy
« on: April 09, 2006, 06:00:22 PM »
Zen does the camp Jordan show have an actual physical address? like 2345 east blah blah street.I need it to use on yahoo maps for exact turn by turn directions.Got any idea? thanks John
Offline copperjewel
« Reply #1 on: April 09, 2006, 07:29:53 PM »
I'm not Zen, but here is what will work. If you use mapquest type in 300 Camp Jordan Parkway for the destination. I checked it from my home address!!
« Reply #2 on: April 09, 2006, 08:56:18 PM »
There's directions and a Google map on the BP8 site: http://www.bugapaluza.com/location/
And here's a link to Google Local if you need to get step-by-step directions too. http://local.google.com/local?f=q&hl=en&q=300+camp+jordan+parkway,+east+ridge,+tn&ll=34.997976,-85.197344&spn=0.025874,0.047035
« Reply #3 on: April 09, 2006, 11:11:03 PM »
Here are some easy turn by turn directions from anywhere . . . First, you need to find 1-75.
If you are in Florida or Georgia when you hit I-75, go NORTH.  When you get to the TN state line, you should be on the exit ramp (TN Exit 1A).  At the top of the ramp you'll hit US-41. It's divided at that point, so you can only go one way - right.  But as soon as you pull onto the highway, scoot across both lanes and get into the turn lane as soon as it starts.  Turn in to the left at the very first place you can turn into.  Go about 50 feet and turn left onto Camp Jordan Parkway - it runs in front of the motels and takes you into Camp Jordan . . . keep going on that road until you see the show.  You can't miss it.  It will be well marked.
If you are in TN or points north when you hit 1-75, go south.  Take TN Exit 1 (WARNING, If you reached 1-75 via 1-24, Exit 1 is, at most, a mile from the I-24/I-75 intersection).  At the top of the ramp, turn left, travel back across the interstate and get into the turn lane as soon as it starts.  Turn in to the left at the very first place you can turn into.  Go about 50 feet and turn left onto Camp Jordan Parkway - it runs in front of the motels and takes you into Camp Jordan . . . keep going on that road until you see the show.  You can't miss it.  It will be well marked.
65dunebuggy
« Reply #4 on: April 10, 2006, 12:13:51 PM »
Thanks Guy's
« Reply #5 on: April 10, 2006, 05:03:00 PM »
I think it will a great day to DRIVE your Buggy up with the wind in your hair, with all the fresh air.   8)  :lol:  :lol:
65dunebuggy
« Reply #6 on: April 10, 2006, 05:25:54 PM »
Bug tech you are going to give me hell no matter what lol.You know what.I drove the buggy day before yesterday and before I even cranked it I was looking and it had drained out about 2 tablespoons of oil.Why can't I have a perfectly dry engine no matter what I do?I know it has been sitting about a month but why should this do this?I have put new stainless steel pushrod tubes on like from the factory.I have used permatex gasket along with a good cork gasket on.You know the ones that are suppose to be the better ones with more cork than rubber.Damn I about give up.I know it's not draining enough to hurt anything except spray's on engine.It doesn't have too much oil in it.It's just one of those things that makes you mad when you try and try.Engine is running great.I need to get a new fuel line on it where it comes from the bottom of the gas tank.I see a crack around the top of it next to the tank.I need to find a pair of forceps that sweeze the line so gas won't run down my arm lol.I think we have some somewhere.What size line is on there so I can tell them at the auto parts store?I also need to get a new gas top gasket.This is for one of these alumium spun tanks.You know what I'm talking about?I haven't had time yet to look it up.If you get bored find me one so I can buy it.I can find the whole tanks but really don't need one. Just the cap and gasket.Well got to go finish cutting the grass.Will see you tonight.
65dunebuggy
« Reply #7 on: April 10, 2006, 10:31:17 PM »
Ok now what is the address for the Ramada.I see all the ones in Chattanooga is this the same for east ridge?
« Reply #8 on: April 10, 2006, 11:17:33 PM »
Here is the link for the Ramada Inn, 6650 Ringold Road, Chattanooga, TN 37412.
Which, by the way, is the one in East Ridge.
« Reply #9 on: April 10, 2006, 11:18:35 PM »
Don't panic !!  Where is the oil drip on the ground in relation with the case ?    in the middle?  flywheel end? pulley end ?  left or right side?   You ain't as old and stiff as I am, throw your butt under there and look.  What about your case vents? 8)
« Reply #10 on: April 10, 2006, 11:33:07 PM »
Quote from: "Russ"
And right above that link are the names, addresses, and phone numbers for all the motels at the I-75 TN Exit 1.  Well, all except the Country Hearth Inn.  I've heard from two people who stayed there last year . . . "Scary" is the nicest thing I've heard about it.
