Window cranking problem..
Topic: Window cranking problem.. (Read 1480 times)
Roadkill
Ooltewah Tn.
May 31, 2008, 04:24:32 PM »
my drivers side window is having a problem rolling up. It rolls down fine but when you start to roll it up it go a bit and then stick and then you pull up on the window some and crank harder and it rolls fine and then sticks again. I will be driving it to the cruise in so any one that can do any thing i will be thankful. If not any ideas what is wrong as i really can not see up in there that well.........
June 01, 2008, 02:11:40 PM »
Take the door panel off and clean the regulator, get all the old grime of and regrease it. It could be outta alignment a bit too,so check that everything lines up good before you reassemble.
