Topic: Weld-in adjusters ?  (Read 3679 times)
Weld-in adjusters ?
« Reply #15 on: October 16, 2008, 03:24:35 PM »
Correct me if I'm wrong:
1) Unbolt 3 spring plate bolts
2) Unbolt 4 torsion bolt plate bolts and remove plate
3) Use jack to lift spring plate up
4) Use pry bar, screwdriver, etc. to pull spring plate back towards you
5) Rotate spring plate upwards 2 splines
6) Reinstall opposite of above instructions
Weld-in adjusters ?
« Reply #16 on: October 16, 2008, 03:53:49 PM »
Thats about it. make sure to mark the springplates and torsion with a paint marker before you start adjusting them. Just in case they slip of you wont loss your starting point.
Weld-in adjusters ?
« Reply #17 on: October 16, 2008, 06:37:12 PM »
second that.
Weld-in adjusters ?
« Reply #18 on: October 16, 2008, 08:58:17 PM »
Thanks alot guys.  I greatly appreciate all of your help!
Weld-in adjusters ?
« Reply #19 on: October 16, 2008, 10:29:18 PM »
No problemo man,if ya need anymore advice on lowering it or run into a problem along the way hit me up.
