Topic: VW Jobs  (Read 1737 times)
VW Jobs
« on: September 16, 2008, 02:14:55 PM »
I checked on the jobs on VW.com today and they have not been removed, actually a new position was posted on 9/12... i certainly don;t qualify for any of the positions... but definitely if any of you do, they are still out there!
VW Jobs
« Reply #1 on: September 17, 2008, 06:11:42 AM »
is there a trick to see the jobs?,  I could not find  them.
VW Jobs
« Reply #2 on: September 17, 2008, 07:12:58 AM »
at the bottom of the homepage on vw.com click "company info" then once that come up click "careers", then "launch career center", then under "positions by location" select "tennessee" and click "search"... then you should be able to see them :)
they have changed the site and it's a bit trickier than it was... guess they want to make sure you're quite web savvy to get the job lol
VW Jobs
« Reply #3 on: September 17, 2008, 08:06:54 AM »
VW Jobs
« Reply #4 on: September 17, 2008, 09:45:27 PM »
Quote from: "Russ"
Direct link: http://www.vwgroupofamericacareers.futurestep.com/Opportunities?location=146&cntry=false
hey now, theres no trick to doing it that way!
VW Jobs
« Reply #5 on: September 18, 2008, 07:29:30 AM »
Thanks ,  I saw the jobs,  is that all they need?   4 purchasing jobs?   Was there more than that?  I'm holding out for "Test Driver"  or "Shake/rattle/Vibration"  Engineer.   SC
VW Jobs
« Reply #6 on: September 18, 2008, 07:54:07 AM »
Quote from: "Smelly_Cat"
Were you looking for test driver or crash test dummy? Cause I think they already filled the crash test dummy positions ;)
The test driving facility is actually based in tampa fl, but vw will deny this... And 10 drivers of debadged unrealsed new models of vws at a gas station will also deny this... But alas circa 1996 when you have a bunch of "concept 1s" driving around, you know you're near the test facility. I haven't personally seen the building, but I'm told its unmarked and they usually pull out before daylight. I think there are a couple more facilities in the country for other types of condition testing... But doubt they'll make another here... But who knows, they just moved the VWoA HQ to VA if you didn't know.
