Topic: Swamp Coolers  (Read 1874 times)
Offline Jason M
Swamp Coolers
« on: April 04, 2012, 03:20:31 PM »
Can you order them new or what?
Re: Swamp Coolers
« Reply #1 on: April 04, 2012, 04:29:16 PM »
Swap meet,  eBay,  check with the old American car guys,  bout 400 bucks for a nice one
Re: Swamp Coolers
« Reply #2 on: April 04, 2012, 04:46:52 PM »
I don't know if they still sell them at Mid-America Motorworks, but I'm pretty sure that Rocky Mountain Motorworks sold a new Swamp Cooler (ABS Plastic Body though) just before they went under.
Re: Swamp Coolers
« Reply #3 on: April 07, 2012, 05:17:11 PM »
All you need is
Box fan
green reusable  air conditioner filter
Little water fountain pump  or water hose to a faucet.  some rubber hose
get water trickling down the filter media
A tray to set the unit in and catch / reuse the water
Maybe a ground fault interrupt just to past code.  SC
Re: Swamp Coolers
« Reply #4 on: April 07, 2012, 10:39:34 PM »
All you need is
Box fan
In case you were even starting to consider it.... don't listen to this guy....  ;)
 ;D
Re: Swamp Coolers
« Reply #5 on: April 08, 2012, 08:35:15 AM »
Here is another one that I did not make up
http://www.ehow.com/way_5551839_diy-swamp-cooler-parts.html
Offline Jason
  • Ringgold Ga
Re: Swamp Coolers
« Reply #6 on: April 08, 2012, 08:55:46 PM »
Oh I know Smelly Cat from way back. I know what he is up to
Re: Swamp Coolers
« Reply #7 on: April 08, 2012, 09:13:51 PM »
I've been considering trying to convert what's left of Homer's dealer installed air conditioning into an evaporative cooler.  I've got two condensors under the bus and the evaporator inside the cab (mounted up on the roof right behind the front seats.  All the hoses are still in place.  About the only thing missing is the compressor.
So, here's what I'm contemplating:  Close up the system by looping the hoses that went to the compressor together, filling the system with water and installing a small pump to make the water flow.  Then all I would have to do is cool the water . . . well as I am moving down the road, if I spray water on the condensor, the wind would evaporate it, cooling the condensor.  The cool water would then flow to the evaporator where the fan would blow across the coils, transfering the heat inside the bus to the water in the system that would then travel to the condensor under the bus where water evaporating from the outside of the condensor would cool it down again.  To make it cool even better, I could pipe the water going back to the evaporator through a cooler full of ice water in the seat of the rear facing chair behind the driver's seat (early bay Westy interior).
What'cha think?
Re: Swamp Coolers
« Reply #8 on: April 08, 2012, 10:34:18 PM »
Call the guy in florida and get a 1/4 HP compressor for that set up and be cool.
It's not like our busses are speed demons.
What, like your top speed will go from 59 MPH to 56 when the compressor fires up.
The dude in florida stated that the new compressors are WAY better than the old stuff.
Re: Swamp Coolers
« Reply #9 on: April 10, 2012, 12:07:05 PM »
It sounds similar to the http://www.coolshirt.net/racing-all.html system that a lot of the SCCA guys use-not me though because there's nowhere to put that cooler in the Vee. It could work, but you might as well use the cooler instead of trying to run it through the condenser. I don't see you getting much cooling out of that on a 90+deg day.
