Topic: Some gas saving tips  (Read 2033 times)
« on: April 25, 2008, 07:15:44 PM »
I'm not sure how true  this is but it had a few new tips for me.  SC
TIPS ON PUMPING GAS...
I don't know what you guys are paying for gasoline.... But here in
California we are also paying higher, up to $3.50 per gallon. But my
line of work is in petroleum for about 31 years now, so here are some
tricks to get more of your money's worth for every gallon.
Here at the Kinder Morgan Pipeline where I work in San Jose, CA we
deliver about 4 million gallons in a 24-hour period thru the pipeline.
One day is diesel the next day is jet fuel, and gasoline, regular and
premium grades.  We have 34-storage tanks here with a total capacity of
16,800,000 gallons.
Only buy or fill up your car or truck in the early morning when the
ground temperature is still cold. Remember that all service stations
have their storage tanks buried below ground. The colder the ground the
more dense the gasoline, when it gets warmer gasoline expands, so buying
in the after noon  or in the evening....your gallon is not exactly a
gallon. In the petroleum business, the specific gravity and the
temperature of the gasoline, diesel and jet fuel, ethanol and other
petroleum products plays an important role.
A 1-degree rise in temperature is a big deal for this business. But the
service stations do not have temperature compensation at the pumps.
When you're filling up do not squeeze the trigger of the nozzle to a
fast mode. If you look you will see that the trigger has three (3)
stages: low, middle, and high. You should be pumping on low speed,
thereby minimizing the vapors that are created while you are pumping.
All hoses at  the pump have a vapor return. If you are pumping on the
fast rate, some other liquid that goes to your tank becomes vapor. Those
vapors are being sucked up and back into the underground storage tank so
you're getting less  worth for your money.
One of the most i mporta nt tips is to fill up when your gas tank is HALF
FULL or HALF EMPTY. The reason for this is, the more gas you have in
your tank the less air occupying its empty space. Gasoline evaporates
faster than you can imagine. Gasoline storage tanks have an internal
floating roof. This roof serves as zero clearance between the gas and
the atmosphere, so it minimizes the evaporation. Unlike service
stations, here where I work, every truck that we load is temperature
compensated so that every gallon is actually the exact amount.
Another reminder, if there is a gasoline truck pumping into the storage
tanks when you stop to buy gas, DO NOT fill up--most likely the gasoline
is being stirred up as the gas is being delivered, and you might pick up
some of the dirt that normally settles on the bottom.  Hope this will
help you get the most value for your money.
« Reply #1 on: April 25, 2008, 07:38:23 PM »
It's mostly bunk: http://www.snopes.com/inboxer/household/gastips.asp
The simplest thing you can do to save gas is just make sure your car is well maintained. Keep the air pressure in the tires up. It's surprising how just a few PSI can make a big difference. Also replace the air filter regularly to keep it clean. After that the biggest impact you can make is with your driving habits. Fast acceleration and hard braking are the worst on fuel economy, try to accelerate smoothly and keep your speed as constant as possible. It's easier in a manual because you can coast downhill and downshift instead of braking to slow down. I routinely push 30 mpg out of my wagon in the city and it's only rated 24 mpg.
Offline Bumble65
  • Ringgold
« Reply #2 on: April 25, 2008, 09:11:30 PM »
I disagree about downshifting uses more fuel in my opinion. Before we moved down here to Savannah, I was getting 35-37 mpg in the Scirocco. That was almost all highway driving at 70mph and around 3200rpm then coasting down hills or up to red lights. I never downshifted since I did not want to bring the rpms back up. Down here I'm mostly city driving and getting 28-30 mpg. The Scirocco is rated from new to get 23 city/29 hwy. I have my tires inflated to 35 psi, except for the one wheel that has a slow leak which I add more about every three days to keep it even with the rest.
Offline Bigdummy
  • Ft Worth , Texas
« Reply #3 on: April 25, 2008, 09:27:11 PM »
My Grandfather said to press your gas and brake as if you have an egg between you foot and the peddles, it works for me.... 8)
« Reply #4 on: April 26, 2008, 09:10:33 AM »
I have to agree that the biggest opportunity for most of us to simply change our driving habbits.  Go easy on the gas and drive like you don't have brakes . . . keep an eye out ahead and try to time the lights . . . sometimes speeding up a little will get you through the light before it turns, but if you know you're going to get caught, try to slow down soon enough that you don't come to a complete stop.  Getting a stationary vehicle moving takes a lot more energy than slowly accelerating a rolling vehicle.
My old Buick Reatta had a fuel use computer on it.  I could usually squeeze 28-30 mpg average out of it by monitoring the instant mpg.  If anyone else in the family drove it, it got 19-20 mpg.  If I had tuned it up and aired the tires up correctly, I probably could have gotten 32 or more out of it.
« Reply #5 on: April 26, 2008, 09:21:41 AM »
I also have to dissagree with the advice to fill up at half a tank.  Gas is heavy.  The more weight you carry around, the more fuel you use.  If you keep the fuel level low, you'll get better milage.  I have also discoverd that if Homer is moving at 60mph and sucks the tank dry just past the Walker County Civic Center, I can coast over a mile to within walking distance of work.  I thought it was a fluke the first time I did it, so I've tried it about a dozen times and it always works.  It works so well that I've tried it in other vechicles.  I know it also works in a Chevette, a Cavilier, a Reatta, a Beetle and a Dasher.  I haven't tried it in a Passat . . . yet.  So if you ever see Homer (or any other vehicle that I might be driving) sitting on the side of Hwy 27 between the Chickamauga Creek bridge and gate 5 of Shaw Plant SI, I'm not broke down, I just decided to save a little gas on the way to work that morning.   :lol:
« Reply #6 on: May 04, 2008, 10:48:39 AM »
Most cars get their best mileage between 50 and 55 mph. Anything over that, and you're losing about 5% to 10% for every 5 mph. When I had the "instant mileage" computer in the Sebring every 5 mph over 55 was losing me a couple of miles per gallon over the same stretch of the "Soddybahn" where I'd compare day to day. Another interesting thing to note is that the decrease is geometric due to the increasing wind resistance. Get it over 70 and it really starts dropping off! I think about that when I see some 2.5 ton sport-ute zipping by me at about 80 and wonder if the driver bitches about their $100 fill-ups! :shock:
Am I not keeping up, or is the cost increase much more a function of increased demand rather than supply? I haven't heard a word about a "shortage" of oil, just the amount we are using!
Drive 55 on 5/5! Slow down and save.
Offline Bigdummy
  • Ft Worth , Texas
« Reply #7 on: May 04, 2008, 09:29:38 PM »
Stay home! :lol:
