Topic: Saturday Help  (Read 4822 times)
Offline Roadkill
  • Ooltewah Tn.
Saturday Help
« Reply #15 on: March 07, 2009, 04:41:26 PM »
Ok guys i have the correct intake on ( looks great ). The wire cluster behind the doghouse fixed. The correct valve covers on ( no oil drip ). I also have break lights now and blinkers work. I got the rebuild on the needed areas of the 30 pic carb done and installed. Now all i have to do is get the new distributor out of the box and get that installed so i can get it running correctly. It all starts up and runs now but the idle still can not stay where it should ( but it starts and runs ). After that i need to get Scott to slam the front end for me........... :lol:  ..............Just kidding ......
Saturday Help
« Reply #16 on: March 07, 2009, 05:27:29 PM »
Now you're talking... by the way, don't forget the valve adjustment if you haven't already taken care of that.  I've seen a lot off people throw parts at an engine, and their only problem was a mix of too loose / too tight valves..
Oh, and if you want that front end slammed, it will only happen if we dump the rear too. 8)
No always runnin' downhill '69 Chevelle look-alikes here
Offline Roadkill
  • Ooltewah Tn.
Saturday Help
« Reply #17 on: March 07, 2009, 06:26:56 PM »
I will definately make sure that the valves are done also when i get help with the distributor instalation. As for the slaming the bug, i would like just a small bit in the front because all the speed bumps ( mounds ) on my road to slow traffic will scrape the bottom off the bug ( ask Scott ). But if there is a rule here about doing just front ends  :D then i will keep it stock looking.......
Saturday Help
« Reply #18 on: March 08, 2009, 12:59:40 PM »
2 1/2 inch cb performance Drop spindles,thats al you need for a little drop and still run stock tires. you can get them as kit with new bearings,seals etc. That and 1 outer spline in the bak and your done.
Saturday Help
« Reply #19 on: March 08, 2009, 05:45:05 PM »
Yeah that makes for a pretty good daily driver set-up. 8)
Offline Roadkill
  • Ooltewah Tn.
Saturday Help
« Reply #20 on: March 08, 2009, 08:25:37 PM »
where would i get them and about how much. Money is really tight withh what i just spent on the new distributor and such. Also how easy ( or not ) is it to do.......
Saturday Help
« Reply #21 on: March 08, 2009, 09:09:20 PM »
CB performance, google it,  200 for the spindles,  depends on ball jiont or link pin whether you will need more parts
Saturday Help
« Reply #22 on: March 08, 2009, 09:11:01 PM »
Offline Roadkill
  • Ooltewah Tn.
Saturday Help
« Reply #23 on: March 09, 2009, 12:37:07 AM »
kewl, thanks for the info and the link. $170 bucks is not bad. To bad i can not find a used set for cheaper around here that some one wants to sell. I would love to get Roadkill fully running and those put on by Bugapalooza next month.
Saturday Help
« Reply #24 on: March 09, 2009, 06:19:25 PM »
Hard to find them used, buy em new. There not too hard to do Make sure to ask them about the correct bearings and seals for you car. It varies a lil bit year to year and stock ones sometimes wont work. Just call them and check 1st.
Offline Roadkill
  • Ooltewah Tn.
Saturday Help
« Reply #25 on: March 09, 2009, 06:44:34 PM »
thanks for the info Scott. I will get them new when i get the money together and the time to do it. That will probably be a while though.
