Topic: next project for the mk1 Cabriolet? BOLT IN VR6 KIT!! yes, I said bolt in!  (Read 1589 times)
Offline 74loaf
  • Hixson, TN
yea... I'm starting my savings now... need to source some doner vr6 parts though... I think I found a good engine...still need a tranny and cable shifter... Rick (R&M), remember our conversation on this the other day?
Check the videos... a complete bolt in job now!
http://store.blackforestindustries.com/eumk1vr6cost.html
$899.99 seems like a lot for
- Qty 2 Axles
- Qty 3 mounts (front drivers side, passenger side)
- Qty 3 total bushings (material based on customers selection)
- Qty 12 inner axle bolt
- Qty 2 outer axle hub nuts
- Qty 4 passenger rear mount bolts
- Qty 4 passenger rear mount washers
- Qty 2 drivers mount bolts
- Qty 4 drivers mount washers
- Qty 2 drivers mount nuts
- Qty 1 front engine mount bolt
Thats basically 2 CV axles, 3 mounts, 3 bushings and hardware... seems kinda high...
Offline 74loaf
  • Hixson, TN
well the quality is good... the motor mount bushings are $50 each by themselves... and the axles are new and custom length, and they are the only ones currently on the market who make the bolt-on brackets...
Offline attack chicken
  • Ooltewah
Looks pretty cool! This setup moves everything over, more or less in the middle of the engine bay it looks, much better clearance on the front of the engine.  As far as the cost goes...if you look at how much a good set of VF Engineering mounts go for ($500) it's really not that bad.
They seem to have some reasonably priced exterior stuff for a MK1.
@Russ, they have a badgeless MK2 grill in their clerance section - will that fit the desel?
