Topic: need your good thoughts  (Read 1455 times)
Offline Roadkill
  • Ooltewah Tn.
« on: February 25, 2009, 11:10:41 PM »
ok on thurday morning i am going to go back down to Ider Alabama and get Roadkill from where he has been living sence the move fiasco. If all remember my earlier post on the oil some how leaving my engine. well i am going to check the car out fill it with oil and drive it back here to Chattanooga. So i need all bug owners and other vw oners to think hard for the well being of Roadkill on his way back...........  :D
« Reply #1 on: February 26, 2009, 07:48:02 AM »
I think I would stop often and check on it.  Take some oil with you. Good luck
« Reply #2 on: February 26, 2009, 08:55:23 AM »
Maybe change out the valve cover gaskets before you leave?
Ditto to what he said ^.
Offline Roadkill
  • Ooltewah Tn.
« Reply #3 on: February 26, 2009, 02:47:25 PM »
Thanks for all your good thoughts. Roadkill felt them and is back here in Chattanooga where he belongs. I did put new valve cover gaskets on and a new fuel filter and air filter because they needed to be replaced. I did find the Big problem of the oil loss. I replaced the drivers side valve cover gasket and when i got to the passenger's side i found that the valve cover was really loose. I could not get it to tighten up with the clip thing for nothing so i did what i could and then filled it with oil. I started back and stoped for gas about trenton ga and looked and saw that it was just almost running out. so i checked the oil level and came home. I did not stop once till my driveway and then it just dumped out there. So he is home and ready for some work to be done.
