Topic: Motor is finally in and running good! Almost ready to go!  (Read 1444 times)
Offline 74loaf
  • Hixson, TN
« on: October 07, 2008, 05:28:50 PM »
Ok, so I have the motor in (thanks to help from Mike (LOLA) and some misc. parts from Russ, and some nice slider windows in that I got from GoBusGo.....
The motor is running good (aside from not having the tools or the timing scale to time it with) but I did notice on a short trip out the other day that I am missing one piece to be able to really get around.... For some reason the yahoo I bought this bus from must have "misplaced" the voltage regulator, because it wasnt there now and I did wonder what the 3 wire connector coming from the alternator went to. well, now I do, and I dont have one. so does anyone have one I can buy? I would like to be able to bring the bus to the cruise-in on the 10th but I will need this part to be able to make the run!
I could also use a decent used timing scale to time my motor with since my metal one is illegible from age.
so close now.......
« Reply #1 on: October 08, 2008, 11:13:46 AM »
Don't let that metal timing scale get away from you.  You can re-mark the scale by laying it over one of the plastic scale on some of our member Van.   I think Mike has one on his van.  All you need is to file 2 marks , 0 and 32 degrees.   I like the metal scale . The plastic ones can get all wharped/cracked up .   You might also get lucky and find one.
       I wouldn't stray to far from home until you have the timing right.  You could overheat that new engine and burn somthing up .  Make sure you can see the mark on the pulley real well .  VW didn't stamp them very well and they can be hard to see behind the pulley grill.
       32 degrees at about 1500-1800 RPMs is max advance
Offline 74loaf
  • Hixson, TN
« Reply #2 on: October 08, 2008, 08:57:18 PM »
ok I got my new voltage regulator today, hooked it up, and this is what I got.
ignition on.... battery light on
motor running.... light still on
rev the motor up...light gets brighter???
any ideas as to why it is doing this?
