Topic: Homers Ride  (Read 2140 times)
Homers Ride
« on: June 04, 2007, 10:52:45 AM »
Has anyone heard from our "Demster-Dumpster Duo" Zen and Kile ?
 The world awaits the news !!
Homers Ride
« Reply #1 on: June 04, 2007, 06:18:56 PM »
We made it Effingham AND we made it back.  Homer was enjoying the trip so much that about 95 mile south of Effingham we turned around and went back and started over.   :lol:
We had one or two slight "glitches" along the way.  About 30 miles south of Effingham on the trip up, the left rocker shaft came off.  Put it back on and hit the road again.  We got to the show about 10:30 AM Effingham time.
A slow oil leak turned into a full blown gusher by the time we got there.  I've gained a new appreciation for spring loaded push rod tubes.  Mid-America Motorworks sells a kit with aluminum tubes a SUPER-STRONG spring, seals and double o-rings.  These suckers don't leak.  PERIOD.  Yep, they are a little on the pricey side, but they don't leak.  And you can install them with engine in the car without removing the head.  And they don't leak.
I'll post more about the trip later.  I've got a lot of pictures as well.
Homers Ride
« Reply #2 on: June 06, 2007, 01:12:44 AM »
did you say they don't leak?  :lol:
i really wanted to go... but very glad i didnt since my bus developed a gas leak on the 11mm 4" hose :roll: i ordered some from canada on sunday and then found that tristate had it in stock... so $34 worth of parts from canada ($12 for hose, $12 other parts and $10 shipping) + 2 gallons of gas at $3/gal (to cleveland and back) + $6 at tristate= $43 for a bus that no longer leaks! and a driveway that now has a hole and no telling how much lost gasoline... but hey it no longer leaks and there is always next year for the show!
Homers Ride
« Reply #3 on: June 06, 2007, 07:33:15 PM »
Dang Zen,  what are the warning signs of loose roker arms?  For my reference file of things that i need to check.  Stupie does not have washers on the bolts/nuts/whatever.. that hold the rocker axle down and I would hate to hurt him.  SC
Homers Ride
« Reply #4 on: June 06, 2007, 07:33:17 PM »
Homers Ride
« Reply #5 on: June 06, 2007, 09:54:20 PM »
The only warning sign Homer gave was he was cruising up the interstate at 70 with a good bit of pedal left . . . a few seconds later he was doing 30 with the pedal glued to the floor.  I think one of the nuts had backed off several miles back down the road, but the rocker shaft stayed put until the second nut started backing off . . . then it popped out of place and I went from 4 cylinders to 2 in the blink of an eye.
We didn't have a feeler guage with us and the engine was hot anyway, so we just bolted it back on and finished the trip.  We were about 30 miles away from Effingham when it happend.  After we got there and the engine had a few hours to cool off, we borrowed a feeler gauge and adjusted the valves.  One exhaust valve and one intake valve were a little tight, a couple more were a little loose, and the rest were about right.  Sunday morning, I picked up a set of the aluminum push rod tubes and replace the 4 on the left side . . . they were gushing . . . one actually had a hole in it.  I'll put the other 4 one as soon as I get a chance.  They are leaking a little around the seals, but nothing like the left side was.  After I replace the tubes, I borrowed another feeler gauge and rechecked the valves (I'd had the rocker off and the push rods out).  Two valves were way off again . . . I think I must have swapped two push rods around.  Anyway, it didn't seem to have done any serious damage.  Homer ran like a champ all the way home.
I bought this engine used.  I had adjusted the valves a couple of times, but I've never checked the rocker nuts.  Before you adjust the valves, I guess it would be a good idea to make sure the rocker nuts are tight.   :wink:
Oh, and by the way, those spring loaded aluminum push rod tubes don't leak!!!!
