Topic: Homer Is Alive!!!!!  (Read 44095 times)
Re: Homer Is Alive!!!!!
« Reply #60 on: January 08, 2014, 09:32:23 AM »
768 now!
« Reply #61 on: January 08, 2014, 10:13:58 AM »
 ::) You might want to start one on my S-10 too. I was going to the Dr. yesterday morning and it's dead too.  I haven't started it in couple of weeks.  The battery is fairly new (less than a year old) and has never given a problem, and the lights were not on . . . there's nothing else on it that can pull power with the switch off, so I don't know what's up with it.  I'm too sick and it was way too cold to mess with it.  I was going to hop in the Passat and run to the Dr.'s office . . . against my better judgement, since it doesn't have a current tag or insurance, but it's only about a mile and I was in desperate need of a breathing treatment.  It's been started once since it was wrecked.  It turns over about as fast as I fix Homer.  My trusty battery charger I've had for 35 years burnt out a few months ago and I haven't replaced it.  Joy got off work early caused they closed her quarry down due to the cold weather, so she got home around noon and got me to the local Doc in a Box.  Got a breathing treatment, two shots, 4 prescriptions, blood work and she wanted a chest x-ray . . . and their x-ray machine was suffering from the same thing as Homer, my S-10 and the Passat . . . it wasn't working either.  Had to go to Ft. O for the X-Ray.  Ended up back home about dark.
Oh, the pipes in utility room are swollen and cracked open in a couple of places. That's not a big deal because, well, they are frozen so now leaks . . . until it thaws.  This has happened twice before.  The last time I had to replumb it, I had the forsight to add cut-offs in the basement, so with a quarter turn of two valves, I have those leaks stopped . . . They are no longer a problem . . . at least until Joy decides that dropping quarters in the machines at the local landry mat is no fun.  I have a feeling I won't be alble to put that job off as long as I have Homer.   ;D  By the way, even when the weather is warm, I'm feeling good and board because I have NOTHING to work on . . . I STILL HATE PLUMBING WITH A PASSION!
I don't ever want to have to do this job again.  The utility room is on the back porch and is unheated.  The pipes that feed the washer and the upstairs bathroom run out of the basement, and up through the floor of the utiltiy room.  They are fastened to the back wall of the house (outside our bedroom) so for them to freeze, it has to get REALLY cold and stay that way for quite a while.  We've lived here a little over 20 years and this is the third (maybe the forth) time this has happened.  The original pipes were copper.  I hate working with copper (me, a torch, inside the house. . . you understand).  I replaced it with CPVC.  I hate it too, but I can work with it without burning the house down.  I'm wondering about PEX.  I don't know much about it, but I've heard it withstand freezing without busting.  Any truth to that?
« Reply #62 on: January 08, 2014, 11:18:53 AM »
I have all the tools for pex. I will gladly help you with that if you need. It is an absolute BREEZE!!!
You just solder on the nipple to go between 1/2 copper and the PEX nipple, then you just cut with tubing cutters (like scissors), slip it over and squeeze the bolt-cutter-like crimper ONCE. Its done. doesn't leak and is AWESOME!!!
Let me know if you need help with it. Should take about 20 minutes to replace a simple run of piping if both ends are easy to access.
« Reply #63 on: January 08, 2014, 11:20:38 AM »
Only 20 minutes? You should have plenty of time to fix Homer after that!
« Reply #64 on: January 08, 2014, 11:57:51 AM »
I could bring a battery charger too...
« Reply #65 on: January 08, 2014, 03:15:46 PM »
I'll probably fix the pipes this weekend.  Homer?  Hummm . . . I think it's gonn'a rain, so probably not.  The S-10, gott'a get it going today.  I'll take the battery to AutoZone when Joy gets home and let them charge it and test it.  I might even buy me a new charger while I'm there.
« Reply #66 on: January 09, 2014, 08:02:10 AM »
Good morning! 769 days!
« Reply #67 on: January 09, 2014, 08:26:25 AM »
Seems like only yesterday!
Is the S-10 running?
« Reply #68 on: January 09, 2014, 08:36:27 AM »
Oh boy,
Another slow starter thread...
LOL.
« Reply #69 on: January 09, 2014, 10:27:56 AM »
The S-10 is going.  It's a fairly new Duralast battery, and with no charger and not being able to close enough to jump it (Homer was in the way), I decided to pull the battery and take it AutoZone and let them charge and test it yesterday evening after Joy got home.  I thought I better check the electrolite level before I took it in so they couldn't say it was bad because I let it run low . . . I popped the caps off and the electrolite was just above the plates (as expected for dead battery) but IT WAS FROZEN SOLID!  :o ???  I've never in my life seen ICE in a battery before.  It had been above freezing for several hours and could turn the battery on it's side and not a drop spilled out.  I didn't even know this stuff could freeze even if the temps were near zero!   ???  They said it would take about an hour to charge . . . it took about an hour and half, but afterwards, it tested good and it worked fine this morning.  What do they do up north where it really gets cold and stays that way for weeks on end?  I'm just glad I live in the South!   ;D
« Reply #70 on: January 09, 2014, 10:34:02 AM »
At 100% charge, a battery will freeze at -77F. At 75%, -35F. At 50%, 10F. At 25%, 5F. At 0% (totally discharged), 20F.
found this on the internets. Perhaps your truck wasn't fully charging it back up. Or maybe you just didn't drive it enough.
« Reply #71 on: January 09, 2014, 10:59:12 AM »
It had been sitting for a week or more.  Come to think of it, I've notice my volt meter showing around 10 volts most of the time when it's running . . . I haven't had any issues until now, so I figured the 30 year old gauge was bad . . . maybe the regulator is going bad.   ???  I'll stop this afternoon and have it checked.
« Reply #72 on: January 11, 2014, 12:46:11 PM »
Today is day 771.  So, if I let it sit until next Friday, it'll be 777.  Does that mean I'll win a jackpot or something?  ;D
« Reply #73 on: January 11, 2014, 09:23:15 PM »
Left my battery charger out in the rain,  hope its ok,  left it on the heater vent
« Reply #74 on: January 14, 2014, 10:34:24 AM »
3 more days til JACKPOT!!!! You win a car!!! It just needs gas to run... ;D
