Topic: Homer Is Alive!!!!!  (Read 44093 times)
Re: Homer Is Alive!!!!!
« Reply #135 on: November 14, 2014, 09:15:29 PM »
You may have to flush the heater core,  mine had no heat when I got it
« Reply #136 on: November 15, 2014, 07:47:03 AM »
I put a new heater core in it 3 years ago.  That's the main reason I didn't just sell the car for scrap after the accident.  The heat worked really good until about a week ago . . . the car will warm up to about 180 degrees and sit there.  When it was in the 20s the other night, it never got over 100 degrees.
Offline moneybags
Re:
« Reply #137 on: November 15, 2014, 09:38:06 AM »
Is this the B4 Passat? With an ABA?
« Reply #138 on: November 15, 2014, 10:13:28 AM »
Sounds like thermostat is stuck open
« Reply #139 on: November 15, 2014, 12:22:21 PM »
Thought you were talking about the Tdi
Re:
« Reply #140 on: November 15, 2014, 09:45:17 PM »
Yep, that's the one.
« Reply #141 on: November 15, 2014, 09:52:06 PM »
Yep, it was.  Two bolts hold the flange that the thermostat is under . . . seals with an o-ring.  Sounds like a 10 minute job doesn't it?  It ain't.   :-\  But, the parts were cheap enough and I didn't break anything else while I was fixing it, so I'm happy.  It warms up and sits on 190 now and the the heater works again!
« Reply #142 on: November 16, 2014, 05:21:50 PM »
Finally found the leak in the Passat's right rear tire and got it fixed.  Then the rain set in.  Pulling Homer's oil pressure relief piston and freeing it up got rained out.  All my free time this weekend went into keeping the old Passat roadworthy for a few hundred more miles.   :(  Next weekend . . . if it doesn't rain . . . and nothing else falls apart.  The good news is I once again have heat and I won't have to air up my tire three times a day.
« Reply #143 on: April 07, 2015, 04:37:02 PM »
... 10 days or else the counter starts over again!!!
« Reply #144 on: April 13, 2015, 04:12:06 PM »
4 days!  ;D
I get to dig out my old Zen'omatic counter...
