Topic: First VW project  (Read 1492 times)
Offline Beans318
  • Rainsville AL
    • facebook
First VW project
« on: January 03, 2010, 03:36:02 PM »
Im about to start on my first real car project my dad has been a VW fan for as long as i can remember and we have owned several bugs fastbacks and golfs in the past but this one is going to be mine and last year at the Apr 17th VW show i saw some rat rods and hot rods and it looked like a good semi cheap beginner project any words of wisdom or advise here for a young aspiring VW fan
Re: First VW project
« Reply #1 on: January 03, 2010, 04:58:38 PM »
Quote from: "Beans318"
For a good experiance with any air-cooled VW there are a handful of absolute rules:
Don't try to run a 34 carb with a 009 distributor . . . change your oil and adjust your vavles every 2000 miles . . . adjust your points first, then set your ignition timing at 32 degrees past top dead center under full advance and lock it down . . . read the manual AND ask someone who has done it BEFORE you attempt it . . .
Other than that, make as many VW friends as you can and jump in head first.  If you make a mistake, learn from it and move forward.  And most of all, HAVE FUN!  The last one is the easy part.   8)
If you have any questions or need any help, don't hesitate to post here in the forums!
Offline bubbz
  • Life is good!!
First VW project
« Reply #2 on: January 16, 2010, 11:24:29 PM »
A wise man told me just today "Dont skimp out on the small stuff. That valve spring you didn't replace will be the one that breaks. now its yard art till you go dack in and do it right"...
