Topic: Don't forget, Thursday...  (Read 11303 times)
« Reply #30 on: June 27, 2006, 05:16:51 PM »
they said they cannot determine where the leak is and now the car looks like it will be going back to NC... i think this is my first and last attempt at a "new car"
65dunebuggy
« Reply #31 on: June 27, 2006, 06:50:02 PM »
Did you buy it in NC?Can"t be much to it.You are just wrapped up in it so much right now.Go work on something else to get your mind off it.It's going to be fixed before long.I bet David could fix it in 2 hours if it wasn't under warranty.If you bought it from a dealer it's surely has a 90 day warranty.That's why I alway's buy a car close to where I live lol.As a matter of fact our mini van is at the dealer now getting some things fix.And yes they will stick it to us like they alway's do.They will get at least 100 out of us even with a warranty.It's called a "stick it to um after the warranty" warranty. :lol:
65dunebuggy
« Reply #32 on: June 27, 2006, 06:53:33 PM »
Zen and Herb said they would fix it if you paid them with some hard to get toy's :lol:
« Reply #33 on: June 27, 2006, 08:05:22 PM »
I don't fix oil leaks . . . I make 'em.   :lol:  It keeps the dust down around where I park.  It also makes the surface of the water turn pretty colors when it rains.  As a bonus, when I retire I'm going to drill for oil in my back yard.  8)
« Reply #34 on: June 27, 2006, 11:36:37 PM »
Well if you drill you might hit a gusher with all the oil soaked up from every vw that's been parked out there. Be carefull.
65dunebuggy
« Reply #35 on: June 28, 2006, 09:46:59 AM »
lol oh lord.
« Reply #36 on: June 28, 2006, 10:13:03 AM »
well the plan is to go snatch up someone from chattanooga when i go to the huntsville show... then they will drive either my bug or my bus to high country, and we will drop the bug off then... then i will get it back someday... perhaps at toccoa... that could be a plan... hmmmm.... we'll figure that out later...  i'd love to just have it fixed :( the whole time we were rebuilding the bus's cv axles yesterday i was just worried sick about my car
« Reply #37 on: June 29, 2006, 09:13:24 AM »
Are these shops VW repair shops or general import shops ?  Is this a "dog house" cooler or straight up old style cooler (60s) ?  The reason i'm asking  there are several types of cooler seals. Some will not interchange and its easy to install the wrong ones if you are not on the ball. Of course this is if your cooler itselve is not the culbrit and the case is not cracked.
« Reply #38 on: June 29, 2006, 11:08:05 AM »
the dealer i got it from i believe is general import... but the last place was vw
i believe it is doghouse... i will look and state otherwise later if it is not... i already discussed possibly being diff seals and they said no... then suggested it is leaking from the head studs? but they really dont know and didnt want to deal with it...
this car is a big pain in my @$$
« Reply #39 on: June 29, 2006, 11:19:21 PM »
It can't be that hard to find,could it? :oops:
« Reply #40 on: June 30, 2006, 07:36:55 AM »
i dont know... i just fear its some major problem... cause things like that seem mto happen to me
« Reply #41 on: June 30, 2006, 08:49:19 AM »
I know of at least 3 different types of cooler seals for the old style . The dog house cooler used just one style unless the case was older. The normal dog house use 4 seals, 2 in the case and 2 on the cooler housing.
  I find oil leaks from head studs hard to belive. I would belive if that were the case,most of the leaks would blow out the bottom of the engine and all over the driveway and not on top as you have said. Even if the gaskets on the clylinder bases would blow out the bottom. I have seen cly. base gaskets seep,but not making the mess like you stated.
  If I were doing the job I would look at the cooler and( maybe replace the damn thing anyway) , check the housing, inspect the crankcase for a crack around that area.
  You could even test run the engine out of the car with the fan shoud off to watch whats going on. I have done this before by using a box fan to help cool the engine. You can run it for short times without overheating.
 Cracks in the case are hard to see sometimes until the engine is heated up then they open up and start leaking.
   If you don't want to do all of this,you could give the car back if possible. I guess it depends if you are having a affair the car and want to keep it . Could you get the seller to discount the price of the car enough to cover the cost of repairs ( engine case if needed) and fix the damn thing youselve ? At least you would know what you had. :roll:
« Reply #42 on: June 30, 2006, 09:53:50 AM »
at this point i think it would be leaking all over the driveway.. the second shop had also mentioned it leaking in the front? not sure about that... i park on the grass at home so i can save all the oil for retirement and be like zen and havea  gusher in the yard  :lol:
really i just dont have time to work on ANOTHER car... i have my 73 that i need to fix and my bus... no time for a car i just paid ten grand for... i refuse to fix something that shouldnt be broken... i am taking the car to NC... i'll let them fix it... i already made arrangements...
i am just pissed that they didnt notorize the title transfer, which you dont have to do in fl, but do in NC, so fl follows the NC laws in this case... so i called to tell them so and their reply was "well its not my fault it took you this long to get the paperwork done, i am not going to send you another temporary tag"... that just had me PISSED... as if i have even had time to go out and enjoy the car... i spend my days off taking it 100 miles away to get [not] fixed.... and this is my fault how? i had to have the car with me to get it transferred... you're the dealer, you should know how to fill out the title!!!
« Reply #43 on: July 05, 2006, 10:06:46 AM »
Sorry I'm a little late to this topic, but maybe I can help. I had a '98 Mexican Beetle for around 2 years, until Emissions Testing came to Hamilton County and the bastards wouldn't pass it because it didn't have the OBD II computer. Sold it on ebay for $500 more than I originally paid, so all's well... Check the galleries under "Misty and Anthony's stuff" for pics.
Anyway, I tore into the engine compartment a couple of times, notibly for an alternator replacement. The oil cooler is a doghouse-style, and as near as I could tell, is the same piece as used in the '70s. The car had the same smoking issue at startup, just once in a while, depending on where the valves were when the engine was shut down. Don't worry about it. To help clear up from previous posts, the engine is very similar to the F.I. engines in the late-model Beetles, a 1600 DP, but the FI system has been heavily updated. Otherwise, it is very similar to the older cars' engines and any competent VW mechanic should be able to work on it. Get the right guy on it, and you'll be happy again. Other than the alternator, mine was always reliable.
« Reply #44 on: July 08, 2006, 12:37:37 PM »
VW Girl, are you having to pay for the repairs on this car out of your own pocket??? :?  If so, why are you taking it to NC if you live in FL???? I'm sure there are competent VW techs in your area or at least much closer than NC.
