Topic: Dirty Pics for THE Godfather  (Read 1289 times)
« on: February 08, 2010, 07:47:08 PM »
Here are the pics I need help with Sir Godfather!
With the pedal stop turned away from the normal placement
Pedal stop all the way toward rear and clutch pedal touching pedal stop
Same as above but with pedal touching the plate
Steel part of pedal straight up in the 12 o'clock position
« Reply #1 on: February 08, 2010, 11:19:26 PM »
JR, That stop plate looks too short on the bottom where the bolt goes. I can't see any problem with the pedals. I made one out of some flat stock and made  a longer bolt slot to bring it back further on Albert's cluster.
« Reply #2 on: February 09, 2010, 07:51:36 AM »
JR, Is that stop plate home made ?   I don't recall seeing a stop plate that short
« Reply #3 on: February 09, 2010, 09:14:08 AM »
That's exactly what I was telling ya on the phone last night.  I think the plate is too short.  I bought it from CIP1.  It's a new plate.  I am going to add-on to it so that it is long enough.  Thanks for your input.
« Reply #4 on: February 09, 2010, 09:58:58 AM »
Quote from: "jrcnova"
Sometimes it doesn't sink in but photos don't lie. I think you said  that you replace the pans ?  I wonder if the bolt hole was drilled in the wrong spot ?? I have seen stuff like that on after market parts.
« Reply #5 on: February 09, 2010, 10:01:20 AM »
I believe you are correct.  Time to break out some scrap metal and the welder and add on to my plate.  Thanks for looking at the pics and note that even though you said it was impossible, some things are possible  :D  (before you say it, I know that if everything was as original, it would have been impossible)
« Reply #6 on: February 09, 2010, 11:12:29 AM »
Came in too late in the conversation, but I think David is right. I have had more than one set of pans that, after installed, required a modified pedal stop....
Nothing like precision measurements on aftermarket parts.   :roll:
