Topic: Cleaning small nuts and bolts  (Read 2154 times)
« on: June 19, 2012, 01:43:12 AM »
Since I have taken on the give-a-way motor task, I have received a lot of engines and otherwise that are at least "good for the nuts and bolts" I have disassembled about 6-8 engines in the last year and ended up with a lot of bad cams and cranks, a few busted up cases and what not, but the coffee cans of nuts were piling up. I cleaned up what I needed for the motors these past two years, but that didn't touch what I had stored up.
I started with the carb cleaner dip can. It worked well, but required soaking and lots of rubbing with a paper towel to get clean. And even then, they didn't come all that clean (some rusted, others stained, you know). So I broke down and bought a vibrating cleaner/polisher from Harbor Freight this spring for about $35. I also got the warranty because I read questionable reviews.
My new cleaning approach starts with the dirty parts being put into Purple power. Then are soaked for a few days and then dumped in the driveway and blasted with the hose. If I need to, I resoak in PP ( :D ). Then they come in to my deep sink where  I have a basket and a soap/water mix ready to finish the degreasing.
Then its on towards the floor to dry out good. The best part about the floor is that you can't drop them any farther! Once they are dry, they go into the vibrator with the abrasive material. I don't remember what I used, but it works. It came with my used sand blasting cabinet.
Turn it on and let it run for ~6 hours and....
PRESTO!!!
Dirty bits
Still use the carb bucket some
Drying on my workfloor
Sitting in the media
The vibrating onion
6 hours later....
Clean bolts!
(side by side)
Re: Cleaning small nuts and bolts
« Reply #1 on: June 19, 2012, 08:32:28 AM »
I need a can of just random VW nuts and bolts.
Figure what that'd cost me and let me know.
These cars I get sometimes are lacking some of the nuts and bolts.
Offline 98GTI
  • President
  • CLEVELAND. TN
« Reply #2 on: June 19, 2012, 10:33:34 PM »
 :D I think we should designate Nick the "Official Club Bolt Cleaner". I vote we send him all our nuts and bolts. I have a 5 gallon bucket full!! LOL
« Reply #3 on: June 19, 2012, 11:30:28 PM »
You clean your own nuts!
Offline PapaKoch
  • Treasurer
  • East Ridge, TN
« Reply #4 on: June 20, 2012, 12:28:34 AM »
Nick
It looks like you are getting some great results with your cleaning procedure. I'm not sure if this would work for 'dirty' nuts, but I bet this apple cider vinegar procedure would work for rusty nuts. It sounds a lot less labor intensive... No washing and vibrating just soak the rust off those nuts! Regardless, we have to keep this thread alive if only to see more pictures of Nick playing with his nuts.
« Reply #5 on: June 20, 2012, 08:12:46 AM »
I love this .  Back when Jim Lockhart was closing down, I went to help with his "yard sale". Everybody was looking at the big stuff and was overlooking things like "nuts & bolts". I told a lot of people that they needed to pick up on the nuts &bolts. No takers. I walked out of there with 3 five gallon buckets full of nuts & bolts all greasy and rusty. I used a diluted solution of muratic acid in a plastic bucket and in about 4 hours they were clean and rust free but you better spray something on them as they will re-rust overnight. Just go price all these nuts & bolts. Talk about sticker shock. Have fun.
« Reply #6 on: June 20, 2012, 08:20:01 AM »
LOL, true dat!
