Topic: Any major issues I should look for in a 1978 Super Conv. ?  (Read 2172 times)
« on: August 12, 2008, 10:23:43 AM »
I'm going to look at one tonight, I know the obvious rust isues, but is there any thing else I should be looking at?
I think it is still FI.
Is this an easy swap to carbeurated?
(I know that the block has no hole for the mech pump and It'll have to have a low pressure eclectric put in.....
It is a seek and purchase mission to the ATL....
I appreciate any heads ups you can give me...
« Reply #1 on: August 12, 2008, 10:46:26 AM »
Why would you want to swap it to carbureted?
« Reply #2 on: August 12, 2008, 05:40:41 PM »
It's pretty easy to convert to a carb if you need/want to.  The head tin for a FI Beetle/Stuper Beetle is different from carborated head tin.  Regular tin in a FI car will leave a gap on each side where it can suck hot air back into the engine compartment.  If you don't get anything else from the original engine, you REALLY need the head tin.
As with any Stuper Beetle, you need to make sure the frame head is soild and look at the codition of the inner fenders around the struts . . . the body is part of the suspension system.
And just in case you didn't already know, you can't tow a Stuper with a standard tow bar.  We'll you "can" . . . but don't!
« Reply #3 on: August 13, 2008, 09:24:02 AM »
Why would you convert to carb ?      So you can drive it and not work on it.  Its not IF it will break, Its WHEN it will break and it will often. All you have to do is look in the engine comp. at the spider web of expensive hoses. Just about any one of them will stop the engine if they have the slightest leak. Keeping the hoses on was a big problem.  The engine could cough one time and blow all the hose off. These FI engines had a hard time living past 50K due to the EGR system dumping "junk" back into the crankcase via the air box.  Take one of those "boxes " apart when you are rebuilding the engine and you will find about 2 cups of what looks like ground up Kitty- Litter which in turn hones out rings and bearings.
     Check this out, A 1600 engine with a carb like a 71-74 is rated at 60 HP.  A '75 up 1600 FI engine is rated at 46HP. The valves are the same size as a 40HP.
      The engines that I converted due to very high and I mean high repair cost got about a  mile or two less MPG than a FI engine in perfect condition. A small price to pay to have a car that has a fighting chance to perform for a long while without all the "coughing,splutting,hesitation" trying to out drag the Kenworth next to you at the traffic light. We won't talk about contant fuel leaks and possible engine fires (AKA) late Type-2's.  Normal everyday drivers don't look in the engine comp. everyday or 50 miles, which ever comes first to see if things are OK. Of course contant maints. will help.
     With the Emission CK's now , I don't know what to tell you,but I won't be converting anything back to FI anytime soon.
      If you have a aircooled FI VW and it is seems to be running fine,leave it alone and drive it until it "Craps Out" .  Convert or get a Federal Grant and a jug of "Old Barley Corn" and a roll of Tums
 :lol:  :lol:
« Reply #4 on: August 13, 2008, 10:50:01 AM »
BIG PILE OF RUST....
I am glad we were combining this trip with another reason for going to the ATL.....
The engine looked scary with all those hoses and stuff.
WOW it is more scarry than the autostick...
« Reply #5 on: August 13, 2008, 01:03:58 PM »
Yes indeed !!!      Your auto-stick is a piece of cake compared to that ---Well you know what I mean :lol:  :lol:
« Reply #6 on: August 15, 2008, 10:14:10 PM »
Bah, just convert it to CIS     :D
« Reply #7 on: August 16, 2008, 08:46:55 AM »
CIS ?????  I was thinking more in line like LUCUS( The British prince of darkness) :lol:  :lol:
« Reply #8 on: August 18, 2008, 05:37:52 PM »
I resemble that remark!!!
The Spitfire's lights started getting dim on the way to work this morning and sputtered into the parking spot with no juice whatsoever...a wire found its way loose from the back of the alternator. Got jumped off and made it home fine and its on the charger.
She's lucky she has her looks... :angry1:
« Reply #9 on: August 25, 2008, 10:51:05 AM »
You know the old joke about why the brittish like warm beer....
« Reply #10 on: August 26, 2008, 10:01:09 AM »
Anthony,  Talking about yellow Spitfires, There is a very yellow one for sale on Chickamauga Rd ,  (the road between Lee Highway and East Brainerd Rd.  )   Looked good from the road. I belive its later than yours due to the big bumpers.
